Thread: Speedo, rev counted and heater hights flicker
    Apr 2009
    sheffield
    Default Speedo, rev counted and heater hights flicker
    Sorry should say lights not hights
    Has anyone had this problem?
    The dial illumination for speedo and tacho and also the heating control section do not behave properly. (With headlights off) they come on most of the time and flash off occassionally and stay on for a bit when the car is locked. With headlights on they flicker between full illumination and the correct dimmed setting. A really annoying fault, but does not seem to be triggered by going over bumps or vibration. Anyone got any ideas which connector to take apart and clean, or what else might be going on. The clock light and dimming functions properly while the rest is flickering.
    thanks all
    Apr 2009
    sheffield
    Any ideas, dash board backlight stays on for about 20 minutes after locking the car (also heater buttons stay on, but not the radio backlights ) strange, there lots on here about dash but not working but nothing about it staying on
    Thats' like a needle in a hay stack
    I would suggest phoning three auto electricians and getting quotes to diagnose erratic panel electrics
    You may be lucky and it is just the fuse box which has failed
    Apr 2009
    sheffield
    I'm going to have a look at the earthing points relating to these lights, lets see what happens, fingers crossed.
    Apr 2009
    sheffield
    Just pulled out F26 and F17 (instrument panel fuses ) lights didn't go off!!
    Maybe they are connectod to internal lighting somewhere, that would also explain why the go aff after about 20 minutes after locking the doors.
    Does any one know if this is the case?
    Dec 2011
    Seaham
    Sounds like they are earthing back through the instrument panel??
  1. Poor MPG and light flicker
    By vectra_driver in forum Engine & Drivetrain
    Last Post: 13th February 2012, 19:02
  2. headlight flicker
    By REDBULL 63 in forum Electrical & ICE (including SatNav)
    Last Post: 25th October 2010, 00:52
  3. Sidelight flicker
    By dhwigston in forum Electrical & ICE (including SatNav)
    Last Post: 17th July 2010, 12:51
  4. headlight flicker
    Last Post: 1st November 2009, 21:52
  5. headlight flicker
    By mikeopolo in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2009, 22:48
