Thread: LED bulbs (An annoying subject i know)
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Default LED bulbs (An annoying subject i know)
    There are 100's of threads on here about LED bulbs/ strobing & canbus errors but i'm sure there must be a retrofit fix to stop all the problems. People have suggested resistors can be placed across the LEDs to stop the bulb errors. BUT, why do they strobe? and is there a series of components that could be put inline to stop strobing?
    The only reason i'm asking is that i am looking at changing all the bulbs in my rear light cluster to LED's.
    Regular Member BYGino's Avatar
    Jun 2011
    Lanarkshire, Scotland
    I'm kind guessing here because I don't know enough about the subject but I believe the strobe when the car sends out a quick check to make sure the bulbs are there. The only reason I can think for this to happen with LEDs only is because LEDs are instant on so the pulse is enough to make them strobe. With bulbs, this really short voltage peak probably isn't long enough to produce the heat in the element to make the bulb light and that's why you don't see it with the bulbs.
    If that is the case, perhaps it can be solved with a couple of desecrate devices. I'm thinking a very simple timing switch circuit that has two paths if power is applied for say less than 100ms then the current passes through the resistor after 100ms the circuit switches and sends the current through the LED?
    OK, I'm probably miles away but if I ever get a quiet weekend I'll give it a try.
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    I was thinking a capacitor might do the trick. maybe it would send out enough voltage to but some juice in the cap, but not light the leds?
    Jun 2011
    Quote Originally Posted by BigWilko View Post
    I thought about that too, but as usual, I like to overcomplicate things.
    The problem is though, would the capacitor interfere with the check? I think t may, I'm going to dig out my schematics later and have a look.
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by BYGino View Post
    Does the resistor go in series or parallel? If it's parallel then if the cap was after the resistor it might be ok.
    Dec 2011
    Seaham
    Have you measured he resistance of a standard bulb and then one of a LED bulb?
    From what I can remember from my school days, to increase the resistance you would place it in series,
    Normal bulb = LED Bulb + Resistor
    to reduce the resistance, adding one in parralel using the equation
    1/Normal Bulb = 1/LED Bulb + 1/Resistor
    It is easier to work out with actual figures....
    Oct 2007
    Shropshire
    I have played around with a few capacitors of different values and the strobing either does not stop or you get an error after a little while which does not clear until you disconnect the battery and reconnect it with the capacitor removed....
    What I did get to work was a resistor to cancel the warning and a relay which then powers LEDs from 12v direct. This worked when connected to the car but I never installed it as it seemed to much effort.....
    Dec 2011
    Seaham
    Capacitors are designed to hold a charge.
    I would have thought someone would noe be building LED bulbs that are suitable for CANBUS systems??
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    when the better weather comes i will be using the illumination wire thats spare near the 12v socket then wire them to the led side lights hopefully that should sort it and leave the nomal bulbs in there holders and find some where neatly to put them in the engine bay to light it up lol
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by Ben50n View Post
    They hold charge but release it quickly i.e. not like a battery. If there is a capacitor that is capable of absorbing the charge of the pulses that make the LED's strobe, could that be put in the circuit? I'm crap at electronics.... as you can probably guess.
  1. Replies: 13
    Last Post: 23rd March 2013, 23:10
  2. Bulbs Bulbs Bulbs - non-Xenon .. Best performance?
    By Saf_789 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2012, 08:44
  3. Annoying dog
    By Graeme in forum General Chat
    Last Post: 30th April 2011, 21:00
  4. The dreaded subject................insurance!!!
    By JET SINGH in forum Insurance Chat
    Last Post: 20th November 2008, 20:24
  5. On the subject of tyre safety
    By bandrew in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2006, 08:36
