Results 1 to 10 of 21
Thread: replaced thermo now a problem
    Regular Member dcm23251981's Avatar
    Jul 2011
    burnley
    Default replaced thermo now a problem
    hi all i have a problem replaced the thermo and now i only get hot air through the blows whilst driving but cold when idle what are the causes of that
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    If you get hot air when you take it a drive, then stop and let the engine idle and the air goes cold, there is still air in the system.
    have the car on level ground
    Have interior heating set to maximum heat
    turn engine off and allow to cool.
    Open bleed screw Not sure where it is on the 1.8
    Top up with coolant, untill there is a constant stream coming out the bleed screw.
    Jul 2011
    burnley
    thanks for that or is it easier to just empty and refill?
    Dec 2010
    Glasgow
    Mileage : Near 100K
    Nah, find out where the bleed screw is and that will save you time
    Jul 2011
    burnley
    cheers pal thanks
    Engine : 1.9 CDTi
    Just run it up to temperature with the cap off and the heater control on hot.
    Jul 2011
    burnley
    i have tried that for a good hr cap off heater on full and pumping pipes still no joy
    Jul 2011
    burnley
    and where is bleed screw
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    There is no bleed screw, it should bleed back to the expansion tank naturally.
    Jul 2011
    burnley
    how long will that take or is it just quicker to flush the system and refill since i hve plenty of antifreeze
  1. Battery Flat after thermo change?
    By unknownbullet in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2013, 18:00
  2. What do I need replaced
    By m20_swe in forum Engine & Drivetrain
    Last Post: 25th March 2012, 08:45
  3. Thermo/ Temp issues 2.0DTi
    By OpelVectraC in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2012, 17:31
  4. any one replaced the ecu?
    By twaiter in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2011, 23:44
  5. thermo stat on 1.9 8v
    By BMAstra in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2010, 12:34
