Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Will Super Unleaded Improve My Mpg??
    Regular Member kgsric's Avatar
    Northants
    Default Will Super Unleaded Improve My Mpg??
    just been speaking 2 a mate of mine & he says he only runs his car on super unleaed (optimax etc etc ) & says he gets more power & mpg out of it than standard unleaded, Will my 1.8 sri getmore mpg/mph out of super unleaded, is it worth the extra coupla pence???
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    in a nut shell no but if u drove like a nun then yes u would
    Regular Member Big Davie's Avatar
    Jan 2006
    having a giggle...
    Ive always used super unleaded, until i found V Power from Shell, will deffo give a wee bit more umph....
    Ive also found that im getting some mph more.....
    Regular Member Ross DTi 2.2's Avatar
    Münster, NRW, Germany
    Simple physics dictates that if the fuel is more combustable (higher octane), it will take less high octane fuel to produce the same explosion as a given volume of lower octane fuel. Therefore you will definitely get better fuel economy from a higher octane fuel.
    Your ECU through timing retardation may not allow the engine to produce more bhp from higher octane fuel. So while you may not get a performance increase, you will see more miles from each tank.
    Jul 2006
    Quote Originally Posted by Ross DTi 2.2 View Post
    I've been filling up with BP Ultimate Diesel since I had my Vec, so I have no comparison, but when I get my ECU remapped, will it make any difference that I'm running on a higher octane fuel? Will they be able to alter the timing while they're in there?
    Paul, there is no "timing" as such on a diesel engine as there is no ignition spark required to achieve combustion. On a diesel engine the explosion is created by compression. Injector timing may be able to be altered but I don't know if any of the current remaps incorporate this.
    The BP Ultimate Diesel gives extra power by having a higher cetane (diesel equivalent of octane) rating than standard diesel. Given that there is no ignition timing to retard, the only thing stopping you from gaining power from this fuel is the amount of air available to the engine.
    Diesel ECU remaps take no account of the type of fuel used, they generally just increase the fuel rail pressure thereby putting more fuel into the cylinders with each injector opening. Its not possible to account for cetane rating in a diesel remap as the ECU doesn't have an ignition map and this is what is adjusted along with turbo boost and wastegate actuator pressure on high octane fuel petrol engine remaps.
    Northants
    thanks, do u think the extra miles will outt weigh the extra pence per litre for hight octane petrol?
    I'm not sure about the difference it'll make on a Vectra 1.8. My SEAT Leon Cupra used to get 50 miles per tank less when running on standard unleaded so it was roughly equivalent to 7 litres of fuel better off on super unleaded.
    7 x 90p = £6.30
    Extra cost of super unleaded 3p per litre. 3p x 55(size of fuel tank) = £1.65
    £6.30
    - £1.65
    = £4.65
    So I was saving £4.65 per tank by using Super Unleaded. Standard unleaded may be cheaper but it can often be a false economy.
    Jul 2006
    Ross,
    Thanks - one of the best things about this forum is the ppl who can really explain things, rather than just give a yes/no answer.
    Regular Member Timkel's Avatar
    northants
    i used to run my mondeo v6 on optimax,and i averiged(spell check) an extra 30 miles out of a tank full.
  1. Unleaded or Super unleaded in a new car?
    By John Bishop in forum General Motoring Chat
    Last Post: 10th November 2012, 00:56
  2. Super Unleaded
    By fester999 in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2012, 14:50
  3. super unleaded or not ?
    By micks edition 100 in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2009, 16:58
  4. Super Unleaded in a 1.8
    By @ndy-e in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2008, 12:12
  5. Super Unleaded
    By john_k_sri in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2008, 21:19
