Thread: No air con
    Jul 2011
    gloucestershire
    Trim : Sri
    Engine : 2.0 turbo
    Mileage : 103000
    Default No air con
    Good evening I was wondering if anyone could help me out.
    I have had my air con re-gassed and when I press the button nothing seems to happen. When I first got the car and pressed the button the revs would drop and it would be cold stright away.
    Now I press thebutton and nothing happens.
    Any ideas people??
    Mike
    Regular Member headscratcher's Avatar
    Jan 2012
    dover
    revs drop,
    i thought they went up to like 1500 rpm,
    am i wrong ?
    thats what mine does anyway,fuel consumption is suppossed to rise slightly,
    whats was your average consumption before re gassing?
    Quote Originally Posted by mikey2704 View Post
    When I first got the car.
    And that was when?
    Depends on how long ago you had it regassed, and whether you've been regularly using it since.
    Failure to use it regularly can result in the seals drying out and the gas leaking.
    AC needs to be used all year round - sorry if you already knew that.
    Jul 2011
    gloucestershire
    Trim : Sri
    Engine : 2.0 turbo
    Mileage : 103000
    I had it gassed about a month ago but nothing happens when I press the air on button.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    aircon wont kick in if its really cold outside
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    The compressor will still kick in as the system still acts as a dehumidifier.
    Are you VXR Enough
    13 Post(s)
    but hes saying his aircon dosnt work which i took for meaning that its not throwing out cold air?
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Sounds like the compressor is not kicking in now though. Might be the clutch gone on the compressor gone, a few have had this issue.
    Are you VXR Enough
    13 Post(s)
    or the condensor has been holed
    Dec 2011
    Seaham
    Should take it back to the re-gasser. When they re-gassed my last car, they put in a fluoro dye which could only be seen under Ultra Violet light.
    This made it easy to find any leaks! Which they did, it was a holed condensor.
