Results 1 to 10 of 18
Thread: Retrofit TC and ESP
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Question Retrofit TC and ESP
    Has anybody ever retrofitted the factory TC and ESP? Surely if you have the wiring in the dash for the switch some of what is needed is already there..
    Will swapping the ABS module to one with TC and installing the Yaw sensor then a quick activation with tech2 or some other software do it? Surely there can't be much to this..
    I am not going to do this on my signum as that had it when it left the factory. I am thinking of doing this to the wifes 55 plate vec 1.8 exclusive (non vvt).
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    It sure sounds interesting.. especially the ESP thing (have tc allready)
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    I think if you have the plug all you have to do is run a wire between it and the ABS module. I believe if you don't have the plug at all then the car doesn't have TC.
    Wirral / ellesmere port
    10 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    tc would be easy enough to retro fit but
    esp youve got extra pipes etc that run alongside the brake pipes
    i wanted to do this to my IS3 but after looking into it then it seemed to be
    too much involved but however im sure i cud retro fit esp if i put me mind to
    it
    Jun 2009
    South Coast
    hmmmm I will start off by comparing the vec abs module to the one on my signum to see if its the same.. If it is I will see if i can see it in opcom and if so try and activate it.. If it isn't i will price it up and see if its worth doing, I have seen them on the bay of E at reasonable prices over the last year..
    the ESP may be more complicated to retrofit than i thought so will do a comparison on that to see if i can see what is extra etc
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Subscribed to this
    Regular Member Dennisd's Avatar
    Oct 2010
    Netherlands
    Trim : Sport
    Engine : 1.9dth
    Mileage : 92000
    I have found a retrofit guide for this, although 1 glitch, its in german.I'm Dutch and although both languages look quite similar, i suck in reading it. But maybe somebody can translate it to proper English.
    Here is the link, but you have to be a registered user to see it.
    http://vectracboardv3.plusboard.de/e...ten-t2769.html
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    Well I've got a 56 cdti no tc. I know someone with tech he said get the abs/tc module out a pre face lift and make sure it has tc on. My only problem is everyone on eBay don't tech2 them from the car.
    Jun 2009
    South Coast
    does a used module need to be tech2'd from a car before it can be installed in another then..? I guess it needs the vin changing in it like a used airbag ecu does to make it work properly.. keep the info coming guys..
    I have seen new modules around the bay on occasion..
    Engine : 2.2 Direct
    I can read and understand german.. so if you make a copy to me ill translate it.
  1. IDS retrofit
    By R2XPT in forum Handling & Braking
    Last Post: 28th September 2011, 20:53
  2. AFL retrofit
    By yoyovento in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2011, 13:16
  3. AFL Retrofit
    By davedrinks in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2010, 19:16
  4. Retrofit
    By Jabbekot in forum Styling
    Last Post: 1st April 2010, 22:22
  5. Retrofit Aux In
    By leeds vectra in forum Parts for sale
    Last Post: 26th December 2009, 17:29
vectra c retrofit guides
retrofit esp vectra
vectra c enjoy esp
esp button vectra c
retro fit vectrs tc
