Results 1 to 10 of 14
Thread: car/spanner symbol
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Default car/spanner symbol
    is it right that if the car/spanner symbol pops up just after iv started the car and then it goes off, means that it has codes stored?
    al.
    Full Member Big Sig's Avatar
    Yes, it means its seen a fault in the past that is no longer current. After about 20 restarts it should go unless it sees another fault.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    i thought as much...
    il stick opcom on it and give it a clear out
    cheers
    al
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Could be the glow plug(s) are needing replaced/glow plug relay could be faulty.
    Regular Member Mads's Avatar
    Ipswich,.UK
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    oh... well the cars been stood for 2 months and the battery went flat trying to start it.
    il clear the codes and keep an eye on it.
    al.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Glow plug or plugs. I was getting the same, as soon as I changed my plugs no more light.
    I changed all four.
    It could be old stored codes. But hey should clear after a few fault free starts.
    Quote Originally Posted by Al 22 dti View Post
    al.
    A flat battery and low voltage through out the system could also trigger codes - low voltage ones. Just get it running and clear them, see if they return.
    With the nearly flat battery the glow plugs will be draining the battery
    The EMS might be misunderstanding this and recording it as a glowplug fault
    Monitor this over the next few weeks and compare
    Providing you are taking the car for long runs this should recharge the battery, and the fault should no longer appear
    However if it does then there is an erratic fault that needs resolving
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    i took the battery off and charged it overnight so the battery's ok.
    il give it a few days or if i can get of my arse, il put opcom on it.
    cheers all
    al.
  1. spanner symbol
    By tecg in forum Engine & Drivetrain
    Last Post: 27th May 2012, 19:39
  2. Spanner symbol up???
    By PeterVV in forum Electrical & ICE (including SatNav)
    Last Post: 24th December 2010, 22:43
  3. car with a spanner symbol
    By ric85 in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2010, 18:07
  4. Car symbol with spanner
    By jeffcapes082 in forum Engine & Drivetrain
    Last Post: 1st June 2009, 22:52
  5. car symbol with spanner
    By glynn in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2008, 21:53
