Results 1 to 10 of 22
Thread: no heaters on car
    Regular Member tash's Avatar
    grimsby
    Default no heaters on car
    hey guys been a while,,still got me vectra,came to it yesterday went to put heaters on as cold lol, got no heat coming out,nothing on number 1 number 2 number 3 but only on number 4,,,any ideas guys,,,air con the same only number 4 mode,,,, thanks in advance paul,,,,
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    resistor pack needed
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    Glove box is easy. You'll need a T20 (Torx) bit. Look along the bottom edge of the glove box with it closed, you'll see two or three (can't recall exact number from memory) screws to remove. Same along the top edge. Glove box should now be loose and be able to be removed. Before you just yank it out, pull it out a bit to then let you disconnect the plug on the light that you'll now be able to see. Once you've done that you can safely take it out all the way. the resistor will be at the bottom near the floor.
    you will have to do a lot of bending .it may help if the passenger seat is pushed back as far as it will go
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Pah beaten to it lol
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    FAN RESISTOR on feabay about 23 pounds
    dealers about 32 pounds plus vat
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    Quote Originally Posted by troutybrown View Post
    couldnt load my external hard drive fast enough
    grimsby
    thanks guys,,i will speak to garage moro and get it booked in,,,as i"am useless at out like this,,do we no how much the bit is and rough time on labour ??? as i wont be using vx dealer thanks again
  1. Heaters
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2012, 20:13
  2. Heaters
    By Bazz in forum Bodywork & Interior
    Last Post: 2nd December 2011, 23:45
  3. heaters
    By gary hough in forum Bodywork & Interior
    Last Post: 3rd September 2011, 12:38
  4. Heaters again
    By paulvectrac in forum Engine & Drivetrain
    Last Post: 9th January 2011, 00:32
  5. Heaters
    By kev77 in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2010, 19:09
