Results 1 to 10 of 28
Thread: Headlamp washer's
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    Default Headlamp washer's
    As the title says whats the part number for these for the vec c and is there a kit you can buy or can you buy them separate with the hose etc
    regards
    Paul
    Regular Member Das's Avatar
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    There is a comprehensive thread in the How2 section with all the part numbers.
    gwent
    What model do you have face lift or pre lift as for parts look at the how 2 fit head lights washers it's got all the parts numbers on there also you need tech 2 to turn it on
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    i activated mine with opcom..
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    im gunna just tap into the feed that does my window screen so when i wash the window screen lights will wash as well just need to find the part numbers and where to get them from but i will have a look into the how to guide
    thanks guys
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Tapping into the windscreen wash feed isn't going to give you the required effect or spray pressure unfortunately.
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    why is that then ???
    Nov 2011
    The headlamp washers run a seperate pump i beleive, this is so that it provides the headlamp washers with enough water pressure to dislodge dirt and clean effectively.
    Think of it as a mini jet-wash.
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Quote Originally Posted by MrDerv View Post
    LoL, your no joking.
    wardy23 When you see the thickness of the hose, the size of the pump and realize the normal wiper washers are a 10amp fuse and the headlight washers are a 30amp fuse you know theres a huge difference. Someone on here will be able to activate them via opcom for you for the usual beer tokens. TBH you dont want them going off every time you wash you windscreen as they can empty you washer bottle quicker than the wife can empty your wallet.
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    lmao at the wife bit lol
    im gunna try and source the bits i need
  1. HID headlamp adjusters
    By Ben50n in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2012, 17:22
  2. Dirt in headlamp
    By GTS in forum Bodywork & Interior
    Last Post: 20th February 2011, 23:26
  3. Headlamp Bulbs
    By davieboy1976 in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2009, 11:22
  4. Headlamp protectors
    Last Post: 27th September 2007, 18:49
  5. xenon headlamp Q?
    Last Post: 2nd January 2007, 17:42
