Results 1 to 10 of 16
Thread: Thermostat 2.2dti
    Aug 2010
    york
    Default Thermostat 2.2dti
    i know this has been asked several times,but think i need to replace thermostat,please can you tell me if i need to replace full housing or just thermostat. many thanks !
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    Just the thermostat. It screws out of the housing. I've just changed the stat on my 2.2dti & its made a hell of a difference. The part no is QTH600k (quinton hazel part no).
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    your mpg will be better
    the cabin will be hotter when you put your heater on
    it will run better as well
    the car will heat up quicker as well
    as dave300776 said
    it makes a hell of a difference
    Aug 2010
    york
    Thanks for info ,will get one ordered.
    what sort of price am i looking at from the stealers.
    Aug 2010
    york
    just looked on ebay and it says qth600k thermostat is for a vectra B,mine is a vectra C 2.2 dti are they the same thermostat ???
    Aug 2010
    york
    am i looking at changing the housing unit ??
    Regular Member dcm23251981's Avatar
    Jul 2011
    burnley
    Default replaced thermostat now have a problem
    hi just replaced the thermostat it worked fine for a few hrs and now i only get warm air when driving and goes cold when at idle
    East Midlands
    Could be an air lock,keep squeezing the hoses on rad or if needs be remove heater matrix pipes which go into the bulk head and see if there is coolant dripping,this should bleed the system.
    ps dont go burning yourself though.
    Jul 2011
    burnley
    if its not that what could it be? because when i refilled the system i left the right matrix pipe loose till coolant came out then topped up and ran engine with coolant cap off for about 30 min !!!!
    Aug 2010
    york
    anyone got dealers part number for a 2.2dti 2003 thermostat
  1. Dti Thermostat
    By dave300776 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th January 2012, 13:59
  2. thermostat....
    By Vectra boy in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2011, 11:50
  3. thermostat 2.2 dti
    By tomo610 in forum Diesel Engine related
    Last Post: 9th January 2011, 22:25
  4. 2.2DTi Thermostat
    By si_hoss in forum Engine & Drivetrain
    Last Post: 15th December 2010, 19:27
  5. Thermostat stuck open - 2.2dti
    By cont1204 in forum Engine & Drivetrain
    Last Post: 25th September 2010, 21:45
vectra c QTH600k thermostat
