Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: 2.2 direct.engine engine rattle after approx 5 mins.any ideas?
    Jun 2009
    Middlesex
    Default 2.2 direct.engine engine rattle after approx 5 mins.any ideas?
    (Z22YH) After approx 5 mins of starting engine you can hear a rattle noise coming from the front of the engine.This noise disappears approx 5 minutes later.Could this be the chain tensioner ? The engine oil level is correct.
    The chain & tensioner where replaced 3 years ago.Please Help.
    Jun 2009
    Middlesex
    Anyone got any idea's on this problem? This rattle makes the engine sound a little like a Diesel.A noise that appear after about 5 mins after start up and then after a short time disappears.
    Nov 2007
    cheshire
    does it do it from cold or hot starts?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Its odd that it only does it after 5 mins of start up.
    Jun 2009
    Middlesex
    I know it sounds odd.Think it's mainly when using the car first thing in the day.Engine starts from cold and sounds fine but as i say after 5 mins,engine starts to sound like a diesel and then a short time later noise goes away and sounds fine again.
    Do you think it could be the hydraulic chain tensioner.
    Full Member gibbon7000's Avatar
    lincs
    I would defo get someone to check you timing chain out even if it was only done 3 yrs ago
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Vehicle : SRi
    Mileage : 137000
    Deffo get the chain/tensioner checked out, but you never know it could be as simple as a cracked manifold or loose manifold bolt. As the heat comes in things expand, the cast 2.2 manifold has been known to do this, but I think first thing to check will always be the tensioner and chain.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    What oil you using?
    Jun 2009
    Middlesex
    GM 5W-30 DEXOS2.Can anyone explain a little about the Chain Tensioner on the 2.2 Direct (Z22YH) and how it works.Does it tension with engine oil pressure & what is the NET spring.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Yep the 2.2 tensioner Is on the oil pressure the fix is to fit a z20net tensioner wich is spring loaded
  1. Engine cover rattle and engine cough
    By Hursty103 in forum Engine & Drivetrain
    Last Post: 15th May 2012, 12:22
  2. whining engine for first 10 mins ?
    By sc0tty05 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2011, 02:48
  3. 2.2 engine rattle help please
    By Iezzi-martin in forum Engine & Drivetrain
    Last Post: 5th December 2010, 16:23
  4. engine rattle
    By melvin in forum Engine & Drivetrain
    Last Post: 1st December 2010, 21:54
  5. engine rattle
    By paul wingnut in forum Engine & Drivetrain
    Last Post: 11th July 2009, 13:42
rattle noise vectra b
field remedy 2366
