Results 1 to 10 of 26
Thread: vectra 1.9cdti glow plugs
    Dec 2011
    manchester
    Default vectra 1.9cdti glow plugs
    i`m after a set of glow plugs due to my starting issue and cant seem to figure out if mine is a 8v or a 16v its a vectra 1.9cdti sri 120bhp thanks
    Jun 2006
    St. Helens,Merseyside
    8valve -Z19DT engine
    plenty found here
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by killa_uk View Post
    Get the better branded ones - cheap ones don't last long and test them before putting them in - a while back I bought a set of Bosch plugs and one of them wasn't working when I bought it.
    Vauxhall Trade Club are doing them for £8.26 + vat part number 93180295 about £10 + if not in the club
    Dec 2011
    manchester
    How would you test them?
    Nov 2010
    East Midlands
    Trim : design
    You could check the resistance using a Multimeter - not sure what the readings should be, but if they are all giving the same reading they should be ok. Alternatively what I do is connect a short length of electrical wire to the cable connection on the plug - connect it to the positive terminal of a fully charged 12volt car battery and then touch the body of the plug to the negative post and hold it there, keeping your fingers away from the tip. The tip of the plug should glow white hot within a few seconds - if that happens its ok. A bit primitive I know but your only replicating what happens on the car.
    Dec 2011
    manchester
    Quote Originally Posted by alcutler View Post
    thanks dude will see how it goes and cures my 1 out of 4 problems i have
    Nov 2010
    East Midlands
    Trim : design
    Good luck with it - the only reason I suggest checking them before fitting is that they are a bit of a pain to fit - you don't want to go to all that trouble only to have to take them out again!
    Dec 2011
    manchester
    I thought fitting glow plugs was easy job?
    May 2008
    newcastle
    if you do have a go at changing them & it's a success please please take plenty of photo's & post them as it does not seem like an easy job on the 120's. there are many pipes that seem to be in the way.
    Dec 2011
    manchester
    Quote Originally Posted by john1 View Post
    cheers will do mate
  1. how to change glow plugs on 1.9cdti
    By mr.4dil in forum Diesel Engine related
    Last Post: 11th May 2011, 20:01
  2. Glow plugs - 120 cdti (2004) vectra
    By baldieone in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd March 2011, 18:48
  3. glow plugs SXI vectra 2.2DTI what tap
    By jimmy495 in forum Vectra C / Signum Troubleshooting
    Last Post: 21st October 2010, 00:48
  4. Vectra glow plugs
    By gazza1984 in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2010, 17:50
  5. where are the glow plugs? 1.9cdti 120
    By spartan80 in forum Engine & Drivetrain
    Last Post: 11th April 2008, 20:49
how to change glow plugs on a vauxhall vectra 19 cdti
vauxhall vectra c diesel engine 1.9 cdti 2006 120 bhp glow plug change
