Thread: Adjusting Wiper Park Position
    Barrow In Furness, Cumbria
    Default Adjusting Wiper Park Position
    As above, is this possible without removing the arms from the splines?
    Regular Member Keif's Avatar
    In the Garage
    Nope, wipers will have to be removed.
    Cheers, thought so. Just that someone was saying about a wiper park sensor the other day.
    Blantyre
    U can stop them halfway or any where for that fact as i do this when i cover my winscreen incase of frost if that's what you mean or do u mean them returning to bottom of the windscreen ?
    Engine : 1.9 CDTi
    How do you stop them halfway?
    Blantyre
    Put your keys in and turn ign on, then turn it of, hold the stalk down and the wipers will swipe, release the stalk where u want them to stop , and then remove your keys
    You may have to set the wipers on a swipe to start with but then follow the above
    In the Garage
    I took the question as you wanted to adjust where they sat on your screen when in the parked position.
    The park position at the bottom of the screen. Someone else said they'd adjusted theirs so you can't see them from in the car. I then saw a mention of a wiper park sensor and thought I'd ask.
    Jul 2011
    UK
    Year : 06
    That might be me I adjusted my wipers so they park down abit on screen still see them not a lot tho
  1. Adjusting Handbreak
    By Alank in forum Suspension, Wheels & Brakes
    Last Post: 18th December 2011, 23:26
  2. xenon headlight levelling has failed from safe/park position
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 12th September 2010, 17:31
  3. Wiper Position
    By Matt&Jemz in forum Electrical & ICE (including SatNav)
    Last Post: 7th April 2010, 01:35
  4. adjusting lights
    By bigron1988 in forum Electrical & ICE (including SatNav)
    Last Post: 18th April 2009, 09:54
  5. FLAT FUSION WIPER BLADES KYODO WIPER BLADES Dynamic Flexi Wiper Blades
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2007, 19:40
vectra c forum wiper park
How to set vectra c wipers
vectra c wiper adjustment
vectra wiper park set
adjust wiper park position
vectra c adjust wiper
