Results 1 to 10 of 14
Thread: my cat has escaped!!!
    Regular Member interespray's Avatar
    luton
    Default my cat has escaped!!!
    changed my catalic the other day only to find when i got the old manifold off the chamber in which the cat should be was completely empty all i could see was the n.o1 sensor at the other end, i never expected that. anybody have an explanation?
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Some one has knocked it out to make the car faster
    Regular Member Chuff's Avatar
    Sep 2011
    Oxfordshire for Pleasure, Berkshire for business
    yep, someone has de-catted it the brut force and broom handle route
    thus looking like it has a cat, but hasnt
    Regular Member Das's Avatar
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Are you the first owner? If not possible that the cat has collapsed at some point and the previous owner bashed the insides out. Happens a lot on the 1.8 and is a quick, cheap and easy fix.
    Regular Member Cruize's Avatar
    South East
    Possibly a pre owner gutted it as a quick fix for a failed cat?
    Also overfuelling and excess fuel in the cat can cause the innards to deteriorate and will eventually leave u with a shell.
    luton
    ok well ive had the car since 2005 april and its been running great uptil last year around june had a managment fault and it was missing badly whipped it into the garaged turns out to be the coils so had them changed and ever since then ive had the constant p0420 code coming up so i decided to save up and change the cat and this is what i found
    luton
    Quote Originally Posted by Cruize View Post
    i think thats what must have happened as i do remember at the time the coils went it really stunk of petrol
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    Odd, that, you can remove the pre cat on a 2.2 but the Vec 2.2 doesnt have one. If you remove the cat it will throw a big wobbler. Is there any other wires that dont look stock under there?
    luton
    Nope it was all bulk standard when i first got her, with two previous owners and 30k on the clock im gonna whip the silencer off at some point to see if if there is any debris floating around inside, i just cant get my head round the fact that the cat is completly gone but i would say it defo hasnt been knocked out coz iwould have had a fault code come up ages ago surely
    South East
    When the innards deteriorate they turn into a black charcoal like substance. If they havent completely melted away then thats what you'll be looking for.
