Thread: air box mod
    Nov 2010
    doncaster
    Default air box mod
    people who hav done this to the 1.9 cdti 16v 150 hav you found it improves the fuel economy or makes it worse
    Jul 2011
    UK
    Year : 06
    No real diffrence car more responsive and can hear the turbo more tho
    Regular Member Cruize's Avatar
    South East
    I have the 1.9 CDTi 120. Have to say I havent seen any huge gains tbh mate. But yeah i'd agree I can hear the turbo a little more.
    Oct 2010
    Darlington
    Quote Originally Posted by fjaimo10 View Post
    Certainly does not make economy worse and as it is a mod you can do yourself you have nothing to lose.
    Jun 2009
    Chelmsford
    Ive done this and also taken off pipe between airbox and air feed on grill and mileage is still up around 48/52 mpg and getting nice sound too.
    Dec 2011
    Pembroke
    Just to say that my Vectra SRi 150 had an appalling lack of low end 'pull' so much so that I had to go into first when it really it should have easily pulled second gear.
    I removed the cowl in the bottom of the airbox (It's not a 'flap' as some describe it, flaps move the cowl doesn't) and saw an immediate improvement.
    I then bit the bullet and sawed through the trumpet in the lid of the airbox, cutting it diagonally in half effectively making it an air scoop.
    Itís like driving a different car. Low down torque massively improved and on a run fuel consumption has gone from 45mpg to over 51, Iím assuming because I donít have to depress the accelerator so far for the same result. Itís probably me, but i swear it runs smoother at normal road speeds as well.
    Others have said that these protuberances into the airbox air for noise reduction but I havenít noticed any difference
    Clearly, in standard trim, the airbox is strangling this engine.
    giltbrook
    I have done the mod by taking the piece off the bottom of air box and noticed an increase from 34 to 38 mpg. I have the issue of crap mpg so thought I would give it a go. Just cleaned my egr and boost sensor too so fingers crossed the mpg will creep up as it is shocking at the moment!!
    Dec 2011
    Seaham
    I think the air box mod allows more of the air filter to be used, when I changed my air filter it was only dirty at one end.
    I will see when I come to change it again, after the mod.
