Thread: Sri Turbo Gearbox Crunching
    Jan 2012
    Darlington
    Default Sri Turbo Gearbox Crunching
    Hi
    My Vectra Sri Turbo crunches in between 1st and 2nd gear then 2nd and 3rd gear it has 109,000 miles on the clock does this mean gearbox goosed ??
    Got a list of problems with this car working my way through them lol
    Any help pls
    Andy
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    for the gears you need to drain out the gearbox oil, all 3.2 litres of it and refill it with only 2.4litres, this is the official vauxhall fix for this issue.. I used fully synth Castrol SMX gearbox oil when i did mine
    Jan 2012
    Darlington
    Hi
    thanks that doesn't sound to bad a friend of mine said something about cables been stretched underneath might need replacing not sure what he ment but think i'll go with the oil is it easy to change ??
    Andy
    Jun 2009
    South Coast
    it could be the linkage that needs looking at but you can do the oil yourself and if anything it leaves the gearbox with the correct level of oil and will only help it. as you currently have a process of elimination to go through its worth doing anyway and it may sort it.
    Assuming you have the 2.0turbo if it is your engine code is Z20NET and you have an F40 gearbox for future reference.. Some people thing the F40 is notchy anyway, personally i think its fine and find the F23 to be worse..
    If you do a search on here for linkage you may found some info or somebody who has played with the linkage may eventually look into this thread.
    Full Member gibbon7000's Avatar
    lincs
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Jan 2012
    Darlington
    Some good advice thanks, i'll change the oil this week and go from there i think got loads of problems with this car so i prob be back soon to pick your brains again
    Andy
    Jan 2012
    Darlington
    New to this site but i'm getting great advice and help its great thanks
    Andy
    lincs
    Get your problems listed mate, You'll get all the help you need on here
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    yep what gibbon said if we dont now how to do it or fix it or find it it carnt be done
    Jan 2012
    Darlington
    Gunna sit in morn write big list you will be sick of me in end lol
    I swaped my 1 owner Lexus IS200 full service low milage a real 1 off cost me 3 tyres and a service in nearly 4yrs for this Vectra, i've spent £400 already on the vectra and i've got loads more to do and i've only had it 4 weeks gutted lol but with the help and advice i've had on here i don't think its going to cost me as much as i thought. Love the car though nice power and great handling but take my advice and keep away from swap sites !!
    Andy
  1. Little crunching getting in second gear sometimes
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2011, 09:36
  2. Turbo delay or issue with auto gearbox?
    By DieselHead in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2010, 13:24
  3. Crunching
    By benwalters82 in forum Suspension, Wheels & Brakes
    Last Post: 20th February 2010, 18:15
  4. Crunching gears from 2nd to 4th
    By FinestJammy1 in forum Engine & Drivetrain
    Last Post: 28th August 2008, 11:29
  5. Crunching noise
    By Silver Vectra C in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2007, 21:55
vectra c 2.0 turbo gearbox
