Thread: headlamp switch pinout
    Dec 2011
    kettering
    Default headlamp switch pinout
    i have just fitted fogs to the front of my vec c which dont work aftter programming so im going to hard wire them in through a relay and fuse but im going to try and do it from the front fog pinout off the headlamp switch which i think is pin 8 but would be nice if someone could confirm and if anyone thinks its possible
    i will use the wire before it goes into the bcm
    this is the part i cant get into to program for some reason
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I don't think the wire is 'switched' in the conventional way. It is a pulse switch, so going via a relay will only work whilst you have the button depressed. Unless you intend on fitting a manual on / off switch to operate the relay, or some electronics to change the pulse to an on / off signal.
    Can't help you on the pinout though.
    Dec 2011
    kettering
    argh i didnt think it was going to be that simple
    Dec 2011
    kettering
    just wondering if changing the bcm might help
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    You could wire it up using a pulsed input to switch on and off....
    It wouldn't be too difficult, and would use commonly available parts that aren't expensive, eg relays..
    Dec 2011
    kettering
    im ok with wiring but unsure what i would need to do that have you any ideas im pretty confident on the wire out the swich as the is only 1 wire from switch to bcm on tis wiring diagram a black wire
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    did you wire the front fogs to the wiring diagram as factory as the live from
    each foglamp go into the multiplug under the fusebox to 2 seperate specific
    pinouts and the other wire from each foglamp goes to earth.
    soon as this is done then tech2 and they shud work via the headlamp switch
    Dec 2011
    kettering
    i used the genuine fogs and loom and connected all up
    activated fogs in instruments and under bonnet fuse box just couldnt get into bcm
    so may be i have done something wrong
    but i used proper switch too
    Dec 2011
    kettering
    can it only be done on tech 2
  1. anybody with T.I.S that can look for a wiring pinout?
    By jon1.9cdti in forum Electrical & ICE (including SatNav)
    Last Post: 11th June 2012, 21:53
  2. Pinout needed
    By ScotsDragon in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2010, 01:50
  3. Z22SE 2.2 Gasoline auto ECU Pinout?
    By autodesigns in forum Petrol Engine related
    Last Post: 25th November 2008, 03:09
  4. Pinout for Instrument cluster
    By Darren in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2008, 18:53
  5. how to remove headlamp switch...HELP
    By sri150 in forum Bodywork & Interior
    Last Post: 5th April 2008, 20:01
vectra c headlight switch pin out
