Results 1 to 10 of 17
Thread: Temp gauge not moving!
    Regular Member twinxster's Avatar
    Jan 2012
    north wales
    Vehicle : vauxhall signum
    Trim : design
    Engine : 1,9 cdti 150
    Default Temp gauge not moving!
    Hi everyone, I have a problem with my temperature gauge, when i drive the gauge doesnt move. Plus the exhaust emission light is constantlly on.(has had a new EGR VALVE under warranty.) I drive 40 miles to work and the gauge doesnt move a millimeter. Only time it does move is when the car is stationary(after driving 40 miles) and then it creeps up to 75ish. The car is under warranty, so took it back to the garage(2nd time in 2 weeks,New egr valve plus the Alternator went last week!, but thats another story) and the garage put on a new temperature sensor. Car still the same. So had a look on this forum, and THERMOSTAT came up all the time. So i mentioned this to the garage yesterday, and they said theyd order the part in for me. Went there today to fix it(but garage was busy today and ill have to bring the car in next saturday) so they gave me the part to bring back with me next week to be fitted.(incase it gets lost or used on someone elses car they said) Ive added a photo of the part. Brand new from vauxhall/opel(it has a box with it) I want to know if were on the right track with this part. The garage has its own mechanic, but it took me to mention the thermostat, before they said anything. Is this the cure to my problem??? (I wouldnt take the car back there if it didnt have a 3month warranty on it, but fair play this is the 3rd part theyve given me EGR VALVE,ALTERNATOR,THERMOSTAT. Who knows, by the end of the 3 months i might have brand new everything under the bonnet.
    Regular Member Das's Avatar
    Here
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Yup classic failed thermostat, only rising when stopped or in slow moving traffic.
    Jan 2012
    north wales
    Trim : design
    Could this be connected to the EXHAUST EMISSION light on the dash. And am i safe to drive it for another week. Got 400 miles to do in the next week.(work and back home)
    Here
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Yes its possible it could be. Because the engine is running cooler than it should be it will be over fuelling therefore its probable that the readings at the Lambdas will be out causing teh EML to show.
    Regular Member headscratcher's Avatar
    Jan 2012
    dover
    Quote Originally Posted by twinxster View Post
    Jan 2012
    north wales
    Trim : design
    thanks guys. lucky ive got this forum. The garage i bought it from are clueless
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 128000
    diesel} takes around 6 miles to get to 86 -87 and the needle stays there
    { petrol} takes around 3 miles to get to 87-89 and the needle stays there
    depending on weather and speed doing
    if you turn your heater on and the needle falls back to 70 to 75 its broke
    i know because mine broke
    there are plenty of threads on here about broken thermostats
    mine broke at 53000 miles petrol engine
    i was driving around for a while until i got mine fixed
    it was effecting my mpg
    Here
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    When they change the Thermostat ask them if they can read the fault code then reset it. Keep a note of the code and come back to us.
    Jan 2012
    north wales
    Trim : design
    Mines a diesel, and the needle only moves slightly up to 75ish, only when the car is stationary(with engine running). It wont go further up, and once i drive off the needle goes back down. ive blasted the heaters full blast and still nothing. So i take it that the needle does work. But not how it should
    Jan 2012
    north wales
    Trim : design
    Will do DasArab
  1. Temperture Gauge not moving up
    By akeem in forum Bodywork & Interior
    Last Post: 27th November 2012, 22:12
  2. preface 1.8 temp dial slow to get moving
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2011, 20:50
  3. Whats the normal operating temp when moving?
    By devore in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2010, 18:55
  4. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  5. Temp Gauge
    By BRUCE120 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2007, 20:00
vectra c temp gauge not working
vectra c 2008 temp gauge not working
vectra c temperature gauge not reading
2.0 dti vectra temperature gauge wont move
vectra c not reading temp gauge
temp gauge on vauxhall vectra c 20dti wont work
temperature guage vauhall vectra
vauxhall insignia 2010 temperature gauge fault
vauxhall vectra sri temperature gauge not working
vauxhall vectra engine temperature gauge faults
vectra c engine temperature gauge
