Thread: Has anyone removed fogs to have cold air feeds?
    Liverpool
    Default Has anyone removed fogs to have cold air feeds?
    I am having my bumper re-sprayed in feb/march and I am thinking of getting rid of the fogs and running 2 cold air feeds from the fog cut outs, not 100% tho
    Has anyone done this before?
    South east
    Cold air feeds to what? If it's the airbox, it's a long way from the n/s foglight.
    Cold in the winter, hot in the summer
    The air intake is shielded behind the grille
    The radiator is partially shielded behind the bumper
    The car is designed to take both air flows into account
    I can see a temporary advantage if your engine is overheating, but that issue needs to be investigated and resolved
    Otherwise you really want to do the opposite and reduce the air flow, as this causes the turbulent air in front of the car to slow down as it has no exit route, and in turn increases MPG (but this change will be less than 0.1% so hardly noticeable)
    Regular Member Keif's Avatar
    In the Garage
    The only benefit would be for brake cooling. That's if you're running uprated brakes, and/or track days.
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    the 2.8T have those any ways
    Quote Originally Posted by Keif View Post
    There is a much better kit for this, that channels unused air from underneath the car to the back of the discs which is then expelled to the outside
    The cars with larger discs already have these fitted and are fitted to the underside of the horizontal suspension arms
    In the Garage
    So.....keep the fogs.
    keep the fogs
    Agreed, they are useful to have in certain conditions
    I've not used mine a lot, but used at night in snow, at night in heavy rain, and during extreme fog
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    I thought about it when a badger broke my drivers side fog. I know they do it a lot on MX-5s. Couldn't be bothered in the end and am picking up a new fog unit this weekend
    Oct 2011
    Essex
    Any pictures - or links here?
  1. Have you removed your dpf or not
    By winnie2457 in forum Diesel Engine related
    Last Post: 27th January 2013, 20:55
  2. random cold knock/tick sound when cold - 1.9 cdti
    Last Post: 18th January 2013, 18:59
  3. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  4. who knows about the temperature feeds?
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2010, 13:35
  5. Replies: 9
    Last Post: 15th February 2008, 02:53
