Thread: brake light fault (confused)
    falkirk
    Default brake light fault (confused)
    had brake light lamp come up on dash and fault message "brake light" on checking no bulbs are gone but on one side the lamp below the indicator is on and on the other the second down lamp is on (i assume the first is a back up for the main one failing) also the brake lights work with the ignition off?? and does the vectra have 2 fogs as I only seem to have one lighting.
    have played about with the bulbs but cannot get both clusters doing the same.anyone got an idea of what is wrong?
    Dec 2011
    Seaham
    Vectras only have one fog lamp on the offside cluster.
    I have heard if the bulb is weak and looks like the filament is breaking down and coating the inside of the bulb a silvery colour then the warning light will indeed come on.
    I also understand that the computer will switch which lights it uses as a brake light, so I would try inspecting the bulbs and try popping in some new ones.
    One of the two upper rear brake / tail lights is nearing failure
    Replace both upper bulbs, compare and you will find one is slightly darkened
    The side which was two down has failed, hence why it swaps to the lower position to compensate
    You've not advised whether this was the nearside or offside
    The brake light check works when the ignition is in the on position (engine does not need to be running)
    Yes, Vectra C only has one rear fog light (offside in UK)
    falkirk
    looks like a combination of a dodgy bulb and a iffy connection plug seems to be working ok just now,thanks for the advice
  1. Estate Rear brake light fault?
    By dv8 in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2012, 20:17
  2. Brake light fault indicator.
    By Ste89 in forum Electrical & ICE (including SatNav)
    Last Post: 28th April 2012, 18:15
  3. Brake light fault:-possible cure?
    By pilgrim in forum Electrical & ICE (including SatNav)
    Last Post: 9th June 2011, 09:20
  4. Brake Light fault
    By interceptor-jamie in forum Electrical & ICE (including SatNav)
    Last Post: 23rd April 2011, 21:05
  5. strange brake light fault
    By Bethan39 in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2010, 14:55
