Thread: front washers
    Regular Member coooky's Avatar
    May 2011
    washington
    Default front washers
    My front washers have stopped working but the pump is ok as its washing the rear
    any ideas im going to start with taking the trim off to see if the pipe has come free
    11 Post(s)
    My rear one still worked, despite the filter being blocked. Maybe it doesn't need quite so much water as the front ones as there is only one nozzle?
    Anyway, check out the how2 section for cleaning the filter. It's got my name next to it.
    New Member melvyn8181's Avatar
    Jul 2011
    north lincolnshire
    wiper motor
    Dec 2011
    Portugal
    In my car, when i try wash the front window, dont work.. But when i want to clean, work.
    My CIM Have a problem. I cant configure the cruise and the ESP dont work.
    11 Post(s)
    Quote Originally Posted by melvyn8181 View Post
    wiper motor
    Huh?
    Dec 2011
    Seaham
    Is there a separate pump for the front washers? Try taking the washer bottle out and check that the washer feed pipe is clean, even try an airline to see if you can blow crap out of the washer pipe. I would blow backwards from the jets to the bottle.
    Check the nozzles are clean, if you live in a hard water area, they can lime up, so try cleaning with a pin.
    11 Post(s)
    Quote Originally Posted by Ben50n View Post
    No.
    One pump, but when the rear screen washer is used the polarity to the motor is reversed so that the pump spins the other way.
    May 2011
    washington
    blocked washer jets i managed to unblock the passenger but the drivers is goosed so i have a set of insignia ones on the way
    just need to have a look at the pump as it must not be in right as the water is leaking out
    Jul 2011
    north lincolnshire
    Huh?
    If the wiper motor is faulty , the front washers wont work but the back washers will.
  1. No Washers Front Or Rear!
    By MRLUBBERLUBBER in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2011, 18:04
  2. Bulb Failures & Front Washers Not Working
    By DanR in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2010, 21:04
  3. Washers
    By jlock in forum Bodywork & Interior
    Last Post: 8th March 2010, 21:04
  4. Front washers
    By Nicolas in forum Electrical & ICE (including SatNav)
    Last Post: 23rd February 2010, 19:05
  5. Front washers trickling!
    By Jamie in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2006, 18:08
