Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: reprogram key
    Regular Member eminemme42's Avatar
    Jan 2012
    westmidlands
    Default reprogram key
    can anyone reprogram a key for my 54 reg vectra c
    cheers pete
    Engine : 1.9 CDTi
    Is the key a new never been programmed one?
    Jan 2012
    westmidlands
    Default key
    i havnt got 1 yet im just enquiring before i get one i heard they can be programmed with a tech 2 software
    only what i heard just need some info about what route to go
    cheers pete
    Regular Member Barlow's Avatar
    Jan 2012
    Chester
    Vehicle : Nissan 350Z GT
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    I want to know the answer to this too. I hear it's expensive if Vx do it.
    Jan 2012
    westmidlands
    Default reprogram fob
    on of u clever chaps should know how to do this
    Glasgow
    Only a new key can be programmed, used keys cant be re-programmed.
    Jan 2012
    westmidlands
    how hard is it to reprogram
    Jan 2012
    Chester
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Just found this procedure, not sure it works of course
    1. First open a window (just in case) use existing key (if you have one) place in ignition and turn to on, do not start car.
    2. Use the new key to lock the car, the key not the remote. Now press one of the buttons once on the new key transponder, the lights should flash, wait 10 seconds and press the unlock button, the doors should unlock and the key should be programmed.
    3. If you are programming a second key repeat the above but press the remote button twice, three times for a third key.
    Alternative Method
    Procedure
    1. Switch on ignition; system will then remain in programming mode for 30 seconds.
    2. Briefly press any button on the remote control unit while the unit is in the ignition.
    3. The central locking system locks & unlocks to show that the remote control has been programmed
    http://reviews.ebay.co.uk/Vauxhall-O...00000007277414
    Glasgow
    Quote Originally Posted by Barlow View Post
    Alternative Method
    Procedure
    That does'nt work on a vectra-c maybe a B but not a C.
    Modern vehicles including vectra c keys need to programmed via dealer diagnostic machine tech2 or other software like opcom/vauxcom.
    Jan 2012
    westmidlands
    so if i get the software and hardware i can do it myself
    if so what would i need
  1. EGR Reprogram
    By tinytiger in forum Troubleshooting
    Last Post: 9th September 2011, 17:56
  2. Signum horn and steering wheel buttons not working after key reprogram
    By designit in forum Electrical & ICE (including SatNav)
    Last Post: 23rd June 2010, 00:02
  3. Anyone recommend a dealer to reprogram my CID
    By acorndave in forum Electrical & ICE (including SatNav)
    Last Post: 10th June 2010, 19:46
  4. How to reprogram a key fob
    By lukesignum in forum Electrical & ICE (including SatNav)
    Last Post: 26th March 2010, 11:39
  5. bsr ppc reprogram ??????
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2008, 23:10
