Thread: injectors
    Jan 2012
    catterick
    Default injectors
    Hi new to the site.
    I have vectra 1.9tdti 150 bhp
    I have change one copper washer on the injector.now they is no power to the injectors and will not start.can anyone help.thanks
    Regular Member benny's Avatar
    Feb 2006
    dudley
    are they all plugged in correct ...the cam sensor plugged in right ...have you bled the fue system .....turn the ignition on for 10=15 secs and do this about 5 times and that should bleed most the system ....how do you know you have no power to them ..?...do you have any other pipes removed or the mass air flow disconected ?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Definatly put connectors back properly?
    Apr 2011
    midlands
    Did you change the injector also?? Not 100% but when you try and start it are you getting a puffing from round the top of the said injector?? Also the crap plastic clips on the connectors are known for being crap. i had all this with mine.. had to have a new injector as it wasnt sitting right then had to get new conections. Then week later egr valve goes!!!! Grrrr
    Jan 2012
    catterick
    i have some testing lights.i plugged them into the connectors.could it be the relay.
    Jan 2012
    catterick
    yes.i will check them again.thanks
    Jan 2012
    catterick
    i have fuel right up too the fuel rail.
  1. 2.0t injectors
    By mann3210 in forum General Motoring Chat
    Last Post: 1st January 2012, 15:27
  2. Injectors
    By leighhockey in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2011, 10:49
  3. injectors
    By damo-SRI-T in forum Petrol Engine related
    Last Post: 9th June 2011, 08:02
  4. Injectors? help
    By Ean in forum The 'Off Topic' room
    Last Post: 26th October 2009, 12:56
  5. Injectors
    By andymagee1982 in forum Engine & Drivetrain
    Last Post: 8th November 2008, 20:24
