Thread: splines
    Regular Member IRMSCHER ALBA's Avatar
    broxburn
    Vehicle : vectra
    Trim : sri
    Engine : 1.8 vvt
    Mileage : 54000
    Default splines
    hi does anyone know how many splines are on the steering column on a vectra c sri 1.8 2007 as i am buying a boss kit for it but dont want to have to take off the wheel yet.
    Mileage : 000
    I think plasma..might be the one to answer your question.
    WGAF#5
    Just remove the airbag ... There is a V insert so that can be your start point to count around from
    Remember to disconnect the battery before you attempt to remove the airbag though
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Will Canbus be a problem if the VX wheel is being removed?
    broxburn
    Vehicle : vectra
    Trim : sri
    Engine : 1.8 vvt
    Mileage : 54000
    i bit the bullit and took off steering wheel and it was 64 splines and the steering column diameter was 20 mm also airbag didnt go off phew
