Thread: question for ya !!!!!!!!!!
    New Member melvyn8181's Avatar
    Jul 2011
    north lincolnshire
    Default question for ya !!!!!!!!!!
    the inside of my tyre is wearing , some one today told me the camber on vectra c's cant be adjusted. i should point out its only the front tyres wearing on the inside , the back ones are fine. so is it true the camber cant be adjusted on the front.?
    ps...19" rims
    standard shocks with 35mm apex lowering springs.
    Ex Ro - South East SRIDAN's Avatar
    Out in the Estate
    5 Post(s)
    Vehicle : Sri Estate Navi xp2
    Trim : Leather
    Engine : 1.9 + a little extra
    Mileage : 80,000
    Have you looked at the drop links, tracking etc?
    Jul 2011
    north lincolnshire
    drop links are new.
    tracking seems fine , no pulling to one side.
    Regular Member jimbo1987's Avatar
    Jan 2012
    southwest
    hard cornering m8!
    Jul 2011
    north lincolnshire
    Quote Originally Posted by jimbo1987 View Post
    hard cornering m8!
    tbh i drive like a grandad so not be that.
    right if your rear camber is out it also puts your front out to compensate
    i had 2 front tyres wear so bad on the inner edge that they went through to the metal banding because the rear camber was out due to wornrear trailing arms
    when i had the tyres changed they checked the front tracking and it was spot on
    id get your suspension set up checked
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    You can buy eibach front camber bolts.
    Have never heard of rear camber affecting front camber????
    Engine : 1.9 CDTi
    There is about a degree of adjustment in the bolt holes so you can adjust it a bit.
    Get it 4 wheel aligned and see if it is out.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Wear on the inside edge of the tyre is more commonly associated with toe out.
    Camber (angle of the wheel to the vertical axis when viewed from the front) is not really adjustable, and I cannot see how rear camber will affect front camber. The camber is set by design.
  1. GSI Inner tie rod question.
    By Lee_gsi in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 19:46
  2. question about hid
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2011, 23:15
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. Just a question...!
    By Maxim007 in forum Styling
    Last Post: 26th January 2010, 20:12
  5. BSR question
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 22:55
