Results 1 to 3 of 3
Thread: Airbag connectors in steering wheel HOW TOO ?
    Kingston Upon Hull
    Default Airbag connectors in steering wheel HOW TOO ?
    Hi all is there a how too for fitting a airbag wire cassette in/ behind the steering wheel
    Now the airbag light is part of the mot i will have to fit a new one
    I have had a mate check with his tek2 gear and this is what came up on the code
    Any tips to help me do it will be gratefully received
    Jacko
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    To be honest it is quite hard to explain.
    IMPORTANT - Disconnect battery, wait a few minutes... Or you may get a face full of airbag.
    FROM MEMORY !
    For 4 spoke steering wheel - I assume 3 spoke is similar.
    Remove airbag from steering wheel by releasing the spring clips from behind (screwdriver in the holes and lever the spring retainer out on both sides), and unclips the 2 connectors. Place airbag face up on the floor out of harms way.
    Undo the centre bolt, but leave in a couple of threads whilst you release the steering wheel. They have a habit of suddenly releasing and hitting you in the face !
    Disconnect the steering wheel controls plug.
    When loose fully remove the bolt and remove the steering wheel unthreading the wires / connectors.
    The ribbon cable cartridge is now visible. It just pulls off (I think) and the ribbon will unwind.....
    The plug needs to be disconnected from the CIM module behind the steering wheel. You may have to remove the CIM from the steering column and split into the 2 parts by removing the screws and clips. The main multiplug to wiring harness is on the back on the left of the column. The retention clip needs pulling out and the plug will come out.
    I don't know if you can buy the ribbon wire on it's own.
    When it's all back together the airbag just clips on - re-connect the plugs (be careful they are fully connected and the retainer pushed in) and just align and push on.
    As I said this is from memory and may not be fully accurate as it was a while ago, but it is fairly straight forwards. The ribbon position needs setting - instructions are on the front of the cartridge.
    Kingston Upon Hull
    Thankyou for all the info
    i have priced a new cartridge and it is £204 + vat from main dealers
    Jacko
  1. does a new steering wheel airbag need tech2
    By mhvcbv in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2010, 20:41
  2. Steering wheel - airbag???
    By John3v36 in forum Bodywork & Interior
    Last Post: 18th January 2009, 22:46
  3. which airbag which steering wheel
    By pmw123 in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2007, 09:10
