Thread: Ford Ka
    Edinburgh
    Default Ford Ka
    Just looking for some advice. My wife is in the process of acquiring a Ka from a friend. It's a v reg 1.3. The car only has 42k on the clock and is in good condition. New tyres new exhaust. At £170 it's a steal.
    The only issue with it is that after driving a while when changing gears rather than the revs dropping it seems to rev right up but is fine in gear. Apparently it's been in a couple of times and they can find anything. Just wondering if anyone had any ideas what it might be. My car experience to date has been diesels so petrol engines will be a new experience.
    Sent from my iPhone 4S using Tapatalk
    Nov 2009
    N/A
    Quote Originally Posted by Big Knox View Post
    Is the parked idle speed ok? I don't know if its got similar systems, but on my old fiesta, the power steering pressure sensor wiring had broken, which caused it to over idle alot whilst driving (ie when changing gear) and cause the standing idle to be raised by about 100 - 200 rpm
    Nov 2009
    N/A
    This may even be of help , quoted from Autodata:
    Affected Vehicle:
    Ka, 09/96 - 09/01 (Build code: TL-1G)
    Problem:
    Engine idle speed high during gear changes
    Impression of sticking throttle
    Cause:
    Incorrect throttle position (TP) sensor signal due to poor multi-plug connection
    Remedy:
    Fit modified TP sensor wiring harness/multiplug, part number 1 150 138
    Edinburgh
    You're a star mungo. Thanks for that.
    Nov 2009
    N/A
    no worries
    Feb 2007
    North west
    the killer on low milage cars is lack of servicing, change the plugs and oil & filter ASAP if I were your, plugs can end up snapping in the block if left for years.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Quote Originally Posted by rob 2.2dti View Post
    A mate at work had this with a Ka he bought.
    Full Member Big Sig's Avatar
    Rear subframe bushes go, if they have its about £230 to have them changed iirc.
    Oct 2011
    Essex
    Poke round the fuel filler, the sills, the A pillars, intact anywhere metallic before spending any money! Soak the plugs in wd40, the endure E's like to snap them off. Probably the throttle body gummed to b*ggery however.
    Edinburgh
    Quote Originally Posted by mungo1985
    Affected Vehicle:
    Problem:
    Cause:
    Remedy:
    Finally picked up one of these today. Hopefully fit it tomorrow.
    3 wires and a plug = £53 hope it does the trick. Lol
  1. our new Ford
    By Felix [GER] in forum Non Vectra C/Signum Album
    Last Post: 21st July 2010, 23:44
  2. Help Think Im Ill I Like A FORD
    By Telboy in forum The 'Off Topic' room
    Last Post: 15th May 2010, 12:26
  3. New Ford Ka
    By david173 in forum The 'Off Topic' room
    Last Post: 2nd August 2008, 20:12
  4. Why ford drivers should stay ford drivers
    By DAVO in forum Comedy & Humour
    Last Post: 10th February 2008, 19:56
  5. Ford anyone?
    By rushy in forum General Chat
    Last Post: 16th April 2007, 16:03
1 150 138 ford multiplug
