sat nav cheap here bloke wants to swop takea peek ==
http://www.migweb.co.uk/forums/showthread.php?t=220384&highlight=signum
Hi,
I think .....
You may need a new display for the Sat Nav
You may even need a GPS module to allow the sat nav to function.
Definately need some kind of Tech 2 update for screen and GPS ..
Please let us know if you do get it to work and how much it costs you in the end![]()
Andrew, may want to ask the guy to see the Car Pass and confirm what Model of Vauxhall it came from ... you may also want to give Vauxhall Customer Service a call while you are with the guyto confirm that model was fitted to the said vehicle.
It would be a nightmare if you bought it, it wasn't coded properly (or even it was stolen) and the Tech 2 would not do anything.
I'm sure there is a separate GPS receiver that is fitted in the boot area, I'll have a look on EPC and TIS and PM you
Check out the guys spelling in his replies to questions. Chav and light fingered come to mind (maybe I'm just prejudice!!)
Good Decision Andrew ...
Definatley need a GPS receiver for that unit.
its been looked into before and it is more hassle than what its worth and that if it even does work which i dont think it will
...for what it's worth, you WOULD have to fit a new aerial (the base on a GPS aerial is much bigger - the rest looks the same)
Avic X1 :d
...here is a photo of it Andrew... http://www.vectra-c.com/forum/showpo...61&postcount=6Originally Posted by ABYSS
(should also say not really for this post as it is not cheap!)
Mark![]()
