Thread: (help needed)
    Regular Member steve19cdti's Avatar
    Nov 2010
    s.wales.bridgend
    Default (help needed)
    started car this morning as normal aftre driving 10-15min noticed ticking over bit high and wont go down got bk home and turn it off then restarted it it wouldent start its like battery goin flat iv had no problem with this battery bn great ive checked the voltedge 12.5 volts in here
    so pluged here in to a op-com and these come
    u2108-70 can bus communication with abs/tc
    p1811-71 torque signel malfuction can
    po500-7e vehicle speed signel range/porformance
    po500-7f "" "" ""
    eny idea where these r on my car and how to adress them is a vectra 1.9cdti 120
    Nov 2010
    s.wales.bridgend
    enyone think it could be starter motor y i ask its like the moter downt wont to turn over loads off battery power
    Jul 2011
    UK
    Year : 06
    Maybe alternator mine did the same then battery light came on
    Nov 2010
    s.wales.bridgend
    i v tryed again and no joy starter wont even turn over just clicking
    Dec 2011
    Seaham
    Battery can still be faulty even though it is reading over 12volts. Try borrowing another battery and give it another go.
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by steve19cdti View Post
    Sounds like the starter solenoid - but can't see why that would affect engine revs - as said before try a good battery before doing anything else.
    Nov 2010
    s.wales.bridgend
    starter motors off it looks shot loads off play tryed to injage the starter clicking like no tomorow
    Nov 2010
    s.wales.bridgend
    thank every one for the comment changed he starter still no joy then cheacked battery loads off voltage couldnt cheack alternater till engine was running so sis let me borrow here battery hay presto car started so now now the battery was the problem so now cheacked the alternater and that was ****ed not charging at all so got alternater today just finnished fitting it whot a job working lovely
    in aprill last year bought a battery from frf by me £67.67p with 5y garantee so took it bk today to parts thay couldnt take it not untill service departmant cheacks it out first what a ***en pain in the ars guys while i was there the guy told me that the vec has a recal on had brake spring enyone had this done yet
    Dec 2011
    Seaham
    Pleased to here you have got it sorted. Its possible that the failing alternator has goosed your battery.
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  5. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
