Results 1 to 10 of 22
Thread: V6 CDTI engine issues
    Regular Member bigdave1701's Avatar
    York
    Default V6 CDTI engine issues
    Are the V6 CDTI engines subject to the same issues as the 1.9 CDTI? (ie; inlet maniflold/egr, DMF etc..)
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Dmf yes as you'll be lucky to fine a derv that doesn't suffer dmf failure.
    Egr not so much. The facelift (z30dt) have dpf I believe so these can fail.
    The problems on the v6 are mainly Scv's ( suction control valves) an cause fuel related problems miss fire etc.
    And also can have other fuel related problems.
    Some people have reported egr problems on them aswel.
    The biggest to keep on eye on id the temp gauge v6 suffer from heat and the liners can sink
    Inlet no
    Egr - very rarely only hear of nicks going bad
    Dmf - ill say yes as can be the same
    On any type of engine that has it
    I've had my v6 for 26 months now and touch wood only had wear and rear replacements ( ie brakes , drop links , wheel bearing )
    Sent from my iPhone using My thumb
    York
    Cheers guys. So when test driving I need to check for the usual DMF rattle, check the temp gauge is getting up to 80-90º, How to I check the SCVs?
    York
    I thought I'd asked a similar question about 12 months ago...
    http://www.vectra-c.com/forum/showth...ght=cdti+guide
    Thought I'd re link just in case anyone else is looking for similar answers.
    Quote Originally Posted by bigdave1701 View Post
    If completed under warranty, check with Sureguard
    If not completed under warranty, then a receipt is required, otherwise it is guess work
    However it is possible to check on TECH2
    If this is still inconclusive, then test drive should confirm if this issue exists
    There shouldn't be an issue with the temperature gauge as it should go straight to 80 as soon as the engine has warmed up and moving
    The DMF affects other engines too, so I classify it as Vectra issue, along with lamps, CIM, springs, shocks, etc
    The fuel filter cannot cope with the long service intervals (30K miles / 2 years) and I personally suspect this was instrumental in premature SCV failure
    General concensus is to replace it at 10K miles / 1 year instead
    There doesn't really seem to be anything else engine specifically that is an issue
    However some of us (who have probably had the SCV upgrade / repair) occasionally suffer excessive black smoke followed by safe mode, but this usually only happens once every 3 months / 5K miles
    I am currently investigating a noise around the auxiliary drive belt / tensioner, which other people have also reported
    This is an odd one though as the auxiliary belt has an odd out of sequence change interval (like the cambelt) but I suspect the tensioner itself has a life span of about 6 years / 100K miles
    In the same way as the cambelt interval on VX engines is reduced (from 80K to 40K miles), I am considering swapping this to an inspection at 60K miles and replacement belt and tensioner at the same time as the cambelt
    Another issue (using the term loosely) are failed liners
    However, this is pretty much the end of the engine, as the cost is so high to replace them
    York
    Thanks for the info m8internet.
    Regular Member Sigmacca's Avatar
    Jun 2011
    Skegness
    Had my 3.0 V6 since last July and so far touch wood just one drop link £28 fitted, MOT next month so fingers crossed
    This engine sure will put a smile on your face, Press 'Sport' button and prepare to grin
    Quote Originally Posted by Sigmacca View Post
    You should really replace both sides, the other side won't be far behind
    Equally, as it is suspension component it's not engine specific and so all Vectra suffer this same issue
    Typical life is about 100K miles / 5 years
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    another thing we've seen cropping up on the forum on a number of occasions with the v6 diesel - is fuel pump failure. very expensive problem if it occurs.
    like all cars, there's good and bad. i remember a forum member called "willco" or something like that, and his v6 was a money pit (luckily under warranty). everything went wrong with that one!
  1. Replies: 200
    Last Post: 16th November 2015, 09:23
  2. I need to clean my engine/bay without electrical issues.How?.
    By felixx in forum Detailing and Car Care Discussion
    Last Post: 19th July 2010, 08:40
  3. 1.8 VVT Engine Issues!!!
    By SteB13 in forum Engine & Drivetrain
    Last Post: 7th June 2010, 17:39
  4. Engine Issues? 1.9 CDTi
    By Ean in forum Engine & Drivetrain
    Last Post: 14th April 2009, 19:25
  5. engine issues
    By chinky in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2007, 22:09
