Thread: 2.2 vectra running a bit rough
    Jan 2012
    london
    Default 2.2 vectra running a bit rough
    Hi all, im new here and in a bit of a quandry requiring some help with my 04 plate 2.2 vectra, it has been running a bit rought recently , now it starts but wont keep running , and if it does , when you try to drive off , it cuts immediately, had it checked when it stopped at services and it said throttle body code, the rac cleared it, then it came back with a different code, the patrolman said he had seen this before a couple of times, and thought it was a ecu problem , and it was just throwing up spurious codes, for the hell of it, so from what i ve been reading , i think i shud try the ecu route, and need to know can i just get a 2nd hand one and bolt it straight on, or does it not quite work like that, i have seen about tech 2 needs to do something to reset or reprogram it, so how do i go about getting that done without going to vauxhall, as i aint got much dough to go there , cos im sure the local scrapyard will have 1 somewhere, is this kind of problem frequent and common or have i just been unlucky
    any help much appreciated in advance
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    95 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Post moved to its own thread, The Problems with Forum & Registering section is not for car releated issues..
    Jan 2012
    london
    it got to where it was supposed to go, but via the houses
    Jan 2012
    london
    right ok update, just phoned the local vauxhall dealer, told them i have a 2nd hand unit(dont know if its cleared or not,i think it is), and are they willing to program it to my car, they said yes £114 which is acceptable in my opinion, my question is , WILL they be ABLE to do it? cos they said basically they will try and do it , but if it fails then i still have to pay
    regards
  1. Vectra c 1.8 sri 2006 running very rough and eml on. Plz help
    By sambohev1 in forum Engine & Drivetrain
    Last Post: 6th November 2012, 21:12
  2. vectra 3.2 running rough after chaning cam cover gasket?
    By kelly1234 in forum Engine & Drivetrain
    Last Post: 25th August 2012, 06:45
  3. vectra gsi running rough misfires high idle
    By shaunft in forum Engine & Drivetrain
    Last Post: 9th August 2012, 23:03
  4. sri 150 running rough on start up help?
    By danni_kitch in forum Diesel Engine related
    Last Post: 26th September 2011, 13:30
  5. 2.2 Sri Direct - running rough
    By johnmac in forum Engine & Drivetrain
    Last Post: 24th December 2007, 19:12
