Results 1 to 10 of 26
Thread: MOT Tomorrow
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Default MOT Tomorrow
    What's it going to fail on?
    I've got dibs on headlight alignment and furthermore a broken headlight mount
    scottish region
    Good luck mate
    May 2011
    bispham, blackpool
    good luck i find the best way go their thinking its going to cost you a few hundred to get it through and when it passes just needing a builb your over the moon i was
    Aug 2010
    Leeds
    [QUOTE=BigWilko;1701251]What's it going to fail on?
    It's all a bit fuzzy this crystal ball, you better just take it in and find out for yourself.
    What mileage is it on?
    How long since last third party service?
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    2005
    68k and i serviced it about 3k ago. The garage i bought it from supposedly serviced it 12 months ago when i bought it.
    Regular Member headscratcher's Avatar
    Jan 2012
    dover
    i take it your motor has the dial for headlight adjustment, o/s by cash tray,
    if your worried lower settings,
    as for the headlight mount,well its a failure if they spot it, but for peace of mind , whip some glue over it to hold it just for now, if it dont move they wont fail it lol,
    good luck with the mot though, alllways daunting
    Is this on your 3.0 V6 CDTI ?
    When you did the service, did you also carry out checks on the steering, suspension, etc?
    I'll go for a pass with four advisories, possibly :
    Front suspension and/or steering
    One tyre with nail (or similar)
    Excessive corrosion on exhaust system
    Quote Originally Posted by headscratcher View Post
    Isn't the tester supposed to set position 0 ?
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    If i was the tester i would On tests before, the tester has just sorted it and passed it.
    I'm not sure really what to look for RE: suspension/ steering etc. but everything seems ok. Bizarrely enough there's not too many bad sounds coming from the wheels. The odd creak from the ARB bushes when it's damp and a few other creaks.
    Regular Member Zark's Avatar
    Herts
    mine failed this week... (04 plate 1.8LS on 84k)
    Exhaust hanger failed (needed welding) front o/s spring snapped.
    also got the discs and pads changed at the front as they were an advisory last year, and this year!
    £300 the lot - so not too bad, i guess...?
    Incidentally - still had 6k HIDS in and tester checked beam with the 'lens on a trolley' thing in front of the car... passed no problems... (without headlamp washers, levelling gizmo's etc etc)
  1. Hmm what to do tomorrow?
    By Ginge7289 in forum Detailing and Car Care Discussion
    Last Post: 4th September 2012, 05:01
  2. MOT Tomorrow
    Last Post: 19th March 2010, 18:30
  3. PVS Tomorrow!
    By Netstar in forum General Chat
    Last Post: 7th June 2008, 08:00
  4. My Car is going tomorrow
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2008, 11:08
  5. Sad Day Tomorrow
    By WHOOSH05 in forum General Chat
    Last Post: 11th January 2008, 02:25
