Results 1 to 10 of 15
Thread: rear washer jets
    Sep 2010
    Milton Keynes
    Default rear washer jets
    how do you adjust them
    i cant work it out
    cheers
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    how do you need to adjust it?
    Sep 2010
    Milton Keynes
    towards the window at the moment it cleans the floor :S
    Jun 2009
    South Coast
    hmm tricky,, they are only little things in the third brake light. If you can't put a pin into one and lever it down a little it may be worth just applying a little pressure on them to push them down a bit.. I have not had to alter mine so cannot be sure of the correct solution..
    WGAF#5
    As above I think there pretty much fixed in direction ... It might just Ben clogged or partially blocked causing the misflow...
    A pin/sewing needle very gently inserts may unblock /redirect it
    Sep 2010
    Milton Keynes
    tried that and made it worse lol, how easy is it to replace the them ?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I am sure I have redirected mine using a pin in the past. Push the pin in about 5mm and 'lever' it to move the nozzle.
    Sep 2010
    Milton Keynes
    will give it another go
    Would still like to know how easy it is to change if that doesn't work thou
    Sep 2010
    Milton Keynes
    Full Member Big Sig's Avatar
    Quote Originally Posted by Ste View Post
    Didn't realise you owned a signum
  1. Washer Jets
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2010, 17:20
  2. Washer jets
    By DHobbs in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2010, 16:04
  3. Washer Jets
    By VikBee in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2009, 09:06
  4. Are there any better washer jets out there..
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2008, 20:45
  5. Washer jets....
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2008, 17:59
vectra c move rear washer jet
