Results 1 to 10 of 20
Thread: Windscreen Wipers don't like the cold!
    Regular Member GoldenWonder's Avatar
    Durham
    Default Windscreen Wipers don't like the cold!
    Although we've had few frosts this winter so far, I've noticed a recurring problem with the wipers on my 2006 Vec that happens when the temp. drops below zero.
    The wipers work on normal/fast wipe but the 'flick' wipe only works if you hold down the stalk - when you lift off, the wiper arms stop wherever they are! Plus the wipers have actually continued wiping (in normal mode) even after the ignition was switched off and the keys removed a couple of times.
    Its done this a few times, but only in the frosty conditions. Once the temp has crept up it seems to resolve itself!
    Anyone got any ideas? I guess the frost must be getting into something to make it throw a wobbly!
    Regular Member Lee.J's Avatar
    Nov 2010
    Stockport
    Just had exactly the same mate.
    Had to change my wiper motor due to ingress of water inside the motor. All info here.
    http://www.vectra-c.com/forum/showthread.php?t=153912
    Durham
    My previous Vec (2004) the motor failed and I replaced that. This works fine until the temp is below zero then it acts weird. As soon as its warmed up its fine again!
    Following your thread showed another thread which mentioned the Winter Wiper Safety feature - I'm not sure whether I believe that or not but the symtoms are exactly the same!
    Regular Member dannydm1's Avatar
    Jan 2008
    leeds / wakefield
    comman problem..... had 2 vectras, both have done this when the tempreture drops....
    in my opinion vauxhall should have done a recall on this.
    Durham
    Hmm so another dodgy motor then - or is it a case of strip,clean and re-grease?
    Nov 2010
    Stockport
    Quote Originally Posted by GoldenWonder View Post
    I have stripped my old motor I think it would work now but havent tested it. It needs something round the cover to help seal it, thought of slicone but its not very robust.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I think it is a failure and not a feature.
    Regular Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    Quote Originally Posted by dannydm1 View Post
    Durham
    Time to search through ebay for a motor then!
    I thought the facelight model had seen the end of wiper motor/linkage problems
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 140000
    I have the same problem and it's a right pain, haven't got round to pulling the motor out to have a look, and don't fancy do the mod that has been mentioned in other threads, but then i don't want to buy a new motor and still have the same problem, thankfully it hasn't been that cold this year so hasn't been a problem...........yet
  1. windscreen wipers
    By Lee.J in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2012, 23:26
  2. windscreen wipers ???????
    By shillbag in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2009, 16:59
  3. Windscreen Wipers
    By macdad in forum Bodywork & Interior
    Last Post: 4th February 2008, 22:22
  4. Windscreen wipers
    By *VECTRA 1.8 SatNav* in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2007, 01:10
  5. windscreen wipers
    By jamesr in forum Bodywork & Interior
    Last Post: 1st January 2007, 11:10
