Results 1 to 10 of 18
Thread: EML coming on - Supermarket Fuel?
    Nov 2010
    East Midlands
    Trim : design
    Default EML coming on - Supermarket Fuel?
    A mate of mine with has a 2004 Vectra cdti 120 that is occasionally displaying the EML, although the car is running fine and there are no codes coming up when we check. He has another mate who is a Kia mechanic in a large garage and he has told him that they are getting a lot of cars coming in with similar problems and the common thread seems to be the owners are using Supermarket fuel. They have been advised to change to a 'branded' fuel and in a lot of cases it has solved the problem. Just wondering if any other members have had any experience / views on this. Appreciated this question may have been raised before but have done a cursory search and can't find anything.
    We have checked all the usual suspects - sensor connections, egr valve, replaced the fuel filter, etc but still got the problem.
    Apologise if duplicated post but would appreciate any views
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I've personally noticed that you don't get as much to the tank with morrisons diesel. Just makes you wonder what crap they are eeeking it out with as it's obviously not combustable
    Tesco fuel is a good bit better but I only use shell fuel in my car now
    Dec 2011
    Seaham
    All fuels must reach a certain specification, however "premium" fuels will have additional additives to improve combustion and also clean the engine.
    Still seems to be the age old saying "You get what you pay for!"
    Quote Originally Posted by alcutler View Post
    When the warning light comes up, are you checking right there and then, or are you checking when the warning light has gone out, plus the engine has been restarted several times?
    If it is intermittent then is it only shortly after start up or after driving for some time?
    Personally if it is intermittent and the engine is not going into safe mode, don't worry about it
    I would be more concerned if it was appearing almost 50% of journeys and/or going into safe mode
    Nov 2010
    East Midlands
    Trim : design
    Thanks for your replies - We've checked with the light on and off and nothing shown, its hard to describe exactly when its coming on as it seems to differ - on average after 30 minutes driving and not every journey - stays on until engine switched off and cleared when restarted. The engine has never gone into safe mode!
    Sounds like you are using an incompatible code reader
    If the warning light is on, then a code is live and can be read
    Restarting the engine will clear any previous live warning, hence why it is best read when the warning light is still on
    It is extremely unlikely to be related to the fuel itself, as it is diesel and in general all come from the same refinery
    Nov 2010
    East Midlands
    Trim : design
    I'm using the code reader I can't mention on here and definatley nothing showing - I agree with you it should throw up a fault when the light is on - but nothing. We have tried a Maxiscan handheld code reader that works with this car, showing rpm, temperatures, etc -but still nothing!
    Appreciate what you say about the fuel but having done a bit of googling this morning it looks like the difference is in the additives that Shell, Esso, etc add that Supermarkets don't
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    So your using opcom then
    Your not allowed to discuss it, doesn't mean you can't mention it
    Phone up two or three dealerships
    Discuss the symptoms and see if they will do a full TECH2 on a no-fault no-pay basis :
    If no fault code is found, no charge, and if one is found then pay accordingly
    The dealership I use will happily do this
    As above, make sure the warning light is on, arrive at the premises and leave the engine running so that the warning stays live
    Nov 2010
    East Midlands
    Trim : design
    Can't win - got bollocked last time - oops sorry can't swear can I!!!!!
  1. alot more mpg from non supermarket fuel.
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2011, 17:22
  2. Supermarket ploys
    By Big Dave in forum Comedy & Humour
    Last Post: 21st April 2011, 23:33
  3. Fuel Light Not Coming On
    By clarted in forum Vectra C / Signum Troubleshooting
    Last Post: 11th April 2011, 02:24
  4. Supermarket Fuel - Do You Use It?
    By RobW in forum General Chat
    Last Post: 6th March 2011, 23:26
  5. supermarket/cheap fuel
    By dezzie in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2007, 22:45
supermarket fuel puts eml on
