Thread: Sat Nav head unit isuse plus spanner light on.
    Sep 2011
    leeds
    Default Sat Nav head unit isuse plus spanner light on.
    sat nav inactive have the cd rom help is it the disc or the unit also i have a spanner light coming on now and then hsve changed the valve and now sometimes i lose power turn engine off and then alls ok until the next time any ideas anybody
    Regular Member Robsey's Avatar
    North East Cheshire
    Trim : Energy
    Mileage : 101,000
    I assume that you are new to this car..
    Sat Nav Inactive simply means that you have not yet plotted a destination.
    Spanner light now and then?
    Really need a lot more information..
    Is it affected by speed, ambient temperature, immediately following start up...?
    Which "valve" have you changed?
    Which engine and model year?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    come on robsey where's your crystal ball lol
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    LOL . Ten Cyber pounds says its a CDTI and he has changed the EGR valve
    scottish region
    Quote Originally Posted by AntSSSS View Post
    20 points says its a dti lol
    North East Cheshire
    Trim : Energy
    Mileage : 101,000
    50 gazillion points says it is a 2003 2.2DTi - ha ha... just looked at his profile..
    Hmm - sure there are a few threads about 2.2DTi running problems..
    Suppose the EGR is the most likey one to be changed.
    Firstly - do you know someone with Tech 2, TisWeb, Op-Com or Vaux-com
    If you do, then ask them to "Clear Fault Codes" / "Clear DTC's"
    Then do a refresh of the DTC fault list
    If you changed the valve yourself, take a look to see if you have missed any connections. The fault you loosely describe could be anything from a dodgey wire, loose or corroded connector, blown fuse... the list goes on.
    going back to the tech 2 / opcom thing...a few years ago the wife's 1.9cdti 150 began to run like a bag of turkeys... no power, lots of smoke, and no diesel whine... I feared the dreaded egr valve...
    Clearing the fault log restored everything back to full service.. don't ask me why.. it just worked. and it was free
    Full Member Big Sig's Avatar
    On the 2.2dti it's more likely the boost sensor clogged up, also check for splits in the boost pipes.
  1. New Head Unit
    By Exclusive BV in forum Electrical & ICE (including SatNav)
    Last Post: 31st March 2012, 00:22
  2. What DVD Head Unit
    By e55ex_rob in forum Electrical & ICE (including SatNav)
    Last Post: 22nd March 2012, 14:32
  3. New head unit
    By blackbeauty in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2011, 17:16
  4. New Head unit
    By IBarfoot in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2007, 09:40
