Thread: vectra dti
    Jan 2010
    norfolk
    Default vectra dti
    hi have got oil light flickers on when the engine is warm and at idle soon as you rev it it goes out , car is vectra dti2.0 on 53 plate . where is oil pressure switch is it one of two in sump thanks
    New Member melvyn8181's Avatar
    Jul 2011
    north lincolnshire
    There is an oil sensor on bottom of sump, you sure u got enough oil in there.
    exeter
    if i was you with the amount of trouble you keep getting i would sell it or trade it in . i got the same car but on a 53 plate with 110000 mile and still dont have half problems that you have. did you get the glow plug out ?
    Jan 2010
    norfolk
    Default vectra dti
    no never got glowplug out goin to wait and see if weather gets any better or i might just scrap it yh there is plenty of oil in it
    Nottinghamshire
    I had the same issue with my 2.2 DTi - the oil pressure light flickering at idle. The handbook says this is OK but I wasn't happy with it so decided to investigate...
    Around £13 at a dealer got me a genuine pressure sensor 90569684 and copper washer 11016282. The sensor requires a 24mm deep socket/spanner so I got this from B&Q so that I could torque it up properly.
    First get the car up ramps and remove the 10 Torx screws - 8 underneath and 1 in each wheelarch - to release the undertray. Look up the back of the engine under the turbo and locate the sensor. Release the clip and remove the wiring plug (single wire) and clean around the sensor before removing it using a deep socket or spanner.
    Fit the copper washer to the new sensor and screw it in by hand then tighten to 30Nm. Refit the wiring plug making sure it clips properly into place. Turn the ignition on and check the check the oil pressure warning light comes on and then start the engine and make sure it goes out and doesn't flicker at idle. Get back under the car and check there are no oil leaks from around the sensor (beware of moving parts and hot parts if the engine is running) then refit the undertray before checking the oil pressure light again.
    That's it all done. I did mine a week ago and the oil pressure light hasn't flickered yet, but I'm still keeping a very close eye on it...
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
