Thread: No Power / Throttle response (cold start)
    Jul 2009
    Burton On Trent
    Default No Power / Throttle response (cold start)
    Hi all. not been arount for a while and wondering if you can help shed some light on a recent problem.
    A coule of time now the car seemed really sluggish pulling away in first up to around 2.5k I thouhht nothing much of it at fist and put it down to me not giving enough boot as I pulled away. However after it did it a couple more times. Generally on first use in the morning I figured that I may have a problem in the making.
    When I finished wirk today the car started but wiuld not rev. It sounded like it would possibly stall but then ticked over without any issue. However I could floor he accelerator and nothing at all would happen. After around 2 minutes of this it slowly started to rev more and more and eventually after around 5 minutes I was able to drive home.
    Please shed any light as to what could be the cause of this problem as I have a feeling it is only going to get worse.
    There was no engine management or spanner lights displayed in the dash.
    Thanks all.
    Jul 2009
    Burton On Trent
    Sorry I think a mod needs to move to technical. Thanks
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 136000
    Jul 2009
    Burton On Trent
    Thanks Ste. I will see what I can do. Also I dont think the glow light illiminated tonight but will check that out in the morning. Also going to hook up the diagnostics to see if it throws anything up.
    Jul 2009
    Burton On Trent
    I know i'm bumping this but just wanted to say thanks again. Did it in about 2 hours after work tonight. Solenoid was stuck solid with corrosion.
  1. Bad throttle response
    By Hodgy in forum Engine & Drivetrain
    Last Post: 6th February 2013, 19:21
  2. Bad EGR and no response from the throttle 2,0 DTI
    By ldanieli in forum Engine & Drivetrain
    Last Post: 13th February 2012, 19:38
  3. no power from cold start
    By gazthebigyin in forum Engine & Drivetrain
    Last Post: 8th February 2011, 00:30
  4. Throttle response
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 21st July 2009, 08:27
  5. No Throttle Response When Cold
    By VectraV6CDTi in forum Engine & Drivetrain
    Last Post: 11th January 2007, 18:29
