Results 1 to 10 of 15
Thread: Led conversion gone wrong
    Regular Member Deikliw's Avatar
    Sep 2011
    Perth & Kinross SCOTLAND
    Default Led conversion gone wrong
    Just finished my LED conversion by doing the Instrument Panel (dash), although looking good I have come accross a problem. I had disconnected the battery etc. before dismantaling and taking out the instrument panel, after installing for testing and reconnecting the battery all lit up and all seemed good, so everything was rebuild needles attached etc.however stupidly never disconnected battery and inserted key with dash unatached So I have the AIRBAG light and the SPANNER/CAR light on indicating a fault, Also the cruise control no longer works although otherwise the car drives just fine.
    Any Input from anybody with tupence to throw at this one would be appriciated cheers.
    Regular Member Craig1985's Avatar
    harwich essex
    Will prob just need codes cleared.
    Oct 2007
    Shropshire
    As mentioned, silly mistake just need to take it to vauxhall and get the codes cleared with your tail between your legs!
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Diss the battery for a while see if that testers it first mate
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    Agreed - remove the battery for an hour or so,
    usually sorts about 90% of electronic faults / glitches.
    Sep 2011
    Got use of diagnostic kit and cleared the codes. however the Airbag light just appears again. Sometimes I start the car and it stays off for that running session however restarting the car will normally put it back on. I am thinking loose conection? but where. it says "left front airbag sensor" (NO Communication)
    Sep 2011
    Got rid of the spanner light (Good news there) and the cruise control was down to bad contacts after taking it in and out forcefully (not a good idea as this can damage the C.I.M. Lucky me now fixed with the help of a paper clip to raise the contacts. Think I might do a "how to" on that and should never have followed the advice of pulling sharp and hard.
    Thinkingthe airbag light then is something ive done possible loose conection under seats possibly and/or any other suggestions would be appreciated cheers.
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    left front airbag - is there one you have not connected properly above the glove box?
    seat wiring issues tend to be more prominent in french and italian cars (fiat punto's - pah!!), where the seat position has been moved, and this has loosened either a wire, or the seat connector itself.
    Sep 2011
    I havent connected or disconnected any airbags however are you saying there is a connection in the glovebox somewhere I should be checking?? Im trying to find where all connections could be as last night I went a few journeys with no airbag light, parked the car and switched off for 2 mins . Restarted the car and the Airbag light reappeared. Id appriciate all locations of any plugs in regards to the airbags to check they are seated correctly. thanks in advance..
    Admin plasma's Avatar
    On the Forum
    333 Post(s)
    Engine : 150
    Mileage : 74000
    left front airbag sensor, think thats the G-shock sensor on the front slam panel
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
  1. New steering wheel control needed SMD conversion gone wrong
    By chuckleuk in forum Electrical & ICE (including SatNav)
    Last Post: 9th November 2011, 21:18
  2. Would it be wrong of me....
    By John LE in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2011, 21:59
  3. Wrong place wrong time.
    By silverhairedracer in forum General Chat
    Last Post: 29th October 2008, 14:20
