Results 1 to 10 of 22
Thread: Rear Door Tweeter Size
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Default Rear Door Tweeter Size
    Does anyone know what size the tweeters are in the rear doors?
    Thinking of getting some for my Vec, and i want to fit them to the blanking plate where the window switch would normally sit. There's clips on the rear of the blanking panel, but just wondered what size tweeter would fit in there for the factory fitted look?
    Cheers Chaps!
    Full Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Quote Originally Posted by MrDerv View Post
    Cheers Chaps!
    PM sent to you mate.
    Nov 2011
    Cheers Mr. Knight!
    Jul 2011
    UK
    Do all vecs have the rear door tweeter wiring?. I had a look in my 55 facelift SRI and the weekend and saw that 2s wire came out of the door loom and go into the main speaker and the rest of the loom went up the back of the door behind the membrane. I couldnt tell if I have the additional connectors for the tweeters or not.
    Nov 2011
    I think it's part of the loom if you have rear leccy windows, but i'm making my own loom and crossover to fit the tweeters as i don't have leccy rear windows (yet )
    Yours will probably be Door Speaker, and the other for Central Locking
    In answer to my own question, the Tweeter size is 37mm diameter. And thanks again to Black Knight for the pair i received today
    Jul 2011
    UK
    I have manual windows. Are you planning to make the procedure a how 2?
    Nov 2011
    Never thought of that but I could do! I've only just finished soldering the speaker wire to the VX tweeters (i don't have a connector for them), so i'm going to do my own loom til I decide whether or not to do the rear leccy window conversion.
    Jul 2011
    UK
    Reading elsewhere on the forum it seems the wiring only exists in the loom designed for leccy windows. The plug should be fairly easy to spot apparently up near the speaker some where if it is present? I think I'll leave it. Its a bit of effort for a relatively small gain, unless someone says it's really worth doing.
    Nov 2011
    It's pretty straight forward, i reckon no more than an hour tops. I'll let you know tomorrow after i've finished
    Jul 2011
    UK
    Ok, thankyou.
  1. What size are the speakers in the door
    By Vectra Boi in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2009, 10:57
  2. what size door speakers??
    By bish in forum Vectra C / Signum Car Chat
    Last Post: 7th June 2008, 18:58
  3. rear door tweeter upgrade
    By Brake buster in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2006, 20:54
vauxhall vectra c rear tweeter remove
