Thread: every bump i hear knocking/clunking from front!!!
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Default every bump i hear knocking/clunking from front!!!
    i want to scream, i cannot see it been a broken spring as i have apex springs that are only about 14 month old. I havent hit any bad pot holes i can think of, i have normal shockers if you need that info, but everytime i go over bumps it like a clunk or a bump noise. My subframe was once loose after a clutch fit and it sounds similar to that, this was well over a year ago now... unless subframes come loose again! What you rekon? Is it a big job to tighten a subframe or doesnt it sound like that? Thanks chaps
    Regular Member Toe-side's Avatar
    Dec 2011
    Northumberland
    Did you jack the car up and let the strut extend fully to check for a broken spring?
    morecambe
    34 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    It's either arb bushes drop links or strut tops Luke easy job to change any of them
    Sep 2010
    Leeds
    No, i just ruled out a broken spring due to already having aftermarket ones with supposed lifetime warrenty! Do you rekon it still cud be a spring?
    Dec 2011
    Northumberland
    Its easier to check with the weight off the strut and check the spring tips in the strut cup are correctly located and have not moved. I have has short sections of spring tipps lie broken in the strut cup for 100's of miles with out dislodging
    Paulvectra's tips are spot on for another potential source. Worn Drop links give that 'clunk' noise.
    Full Member coldo's Avatar
    Scotland
    any springs can break unfortunatly.
    I have very recently had allot of issues with noises from my suspension... From research noises seem to typicaly come from one of two problems.
    If your getting a twang sound when turning the wheel from side to side while staionary then it's likley to be the top mounts or the top mount barings.
    IF your getting a clunk whengoing over speed bumps then it is likley to be the drop links or the ARB Bushs... easy to check.... use the search to find ljnks about fixing these
  1. clunking front end
    By andy_richmond in forum Suspension, Wheels & Brakes
    Last Post: 4th January 2013, 21:07
  2. bump stop on front struts do i put them on coilovers
    By 6009tristanb in forum Suspension, Wheels & Brakes
    Last Post: 9th July 2012, 21:41
  3. Knocking/Clunking noise from front suspension
    By MrDerv in forum Suspension, Wheels & Brakes
    Last Post: 21st April 2012, 17:14
  4. If you hear a horrendous knocking noise.....
    By johnseffs in forum Engine & Drivetrain
    Last Post: 13th March 2012, 21:01
  5. I hear knocking noise going over bumps
    By zazaszazas in forum Suspension, Wheels & Brakes
    Last Post: 24th February 2009, 23:43
clunk on every bump
