Thread: car wont start
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    Default car wont start
    hi all, my car will initially start for a second or too then dies, ive used my opcom and i get glow device general error and thats the only fault.
    its a z19dth by the way
    any ideas?
    cheers
    Engine : 1.9 CDTi
    That is telling you you have a fault with the glow plugs that help start the car.
    Is it cold where you are as it will need them to start the car if its really cold.
    Dec 2011
    Seaham
    Try switching the ignition on to bring in the glow plugs and put a voltage meter onto the glow plugs, this will check to see if there is power to the glow plugs. If no power, check the glow plug relay.
    If there is power, I would suggest a new set of glow plugs be fitted.
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    we did have a freeze last night, but i understood that the glow plugs only help to warm the air inside the cylinder. but after cranking the engine for appro 10 minutes i would assume that the process would have warmed the air enough to start.
    Or am i completely wrong guys?
    Engine : 1.9 CDTi
    The glow plugs provide a hot point for the fuel to ignite.
  1. wont start
    By wsophiecat in forum Engine & Drivetrain
    Last Post: 17th December 2011, 17:17
  2. 2.2 cut out now wont start
    By spink1972 in forum Engine & Drivetrain
    Last Post: 22nd April 2011, 08:32
  3. Car wont start - please help
    By zafira in forum Diesel Engine related
    Last Post: 6th November 2010, 14:25
  4. Will not start then it will then it wont????
    By djconfused in forum Engine & Drivetrain
    Last Post: 29th July 2010, 21:37
  5. car wont start!
    By briancdti in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2008, 20:11
