Thread: spanner light and foam in coolant
    Jan 2012
    Blandford forum dorset
    Vehicle : Vectra c
    Engine : Z18XER
    Mileage : 89000
    Default spanner light and foam in coolant
    heya guys first time posting and thought i would start with giving you guys a problem and tell me what it could be.
    got a vectra 54 CDTI 150 and everytime it starts it has a symbol on the little screen that has a spanner over a car. thought it was a service thing so thought nothing of it for a while but on my way home tonight, i had a symbol that looked like a radiator with water half full on it.
    wasnt long till i got home but i looked at the resevoir and found the water was at a reasonable level and opened up the cap and foam was coming out of the overflow and roam was resting on the top of the water. anyone have a idea what this could mean?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Oil in the water
    Dec 2011
    Seaham
    Blown head gasket??
    Take the oil filler cap off and look for cream cheese on it. thats water in the oil. Normally points to a blown head gasket, unless you do lots of very short journeys and its condensation in the engine, but I would guess head gasket failure or failing.
    Oct 2011
    Essex
    Get a garage to do a pressure test on the cooling system, a pretty fair indicator of wether you have head gasket failure (gasket separating cooling water from engine oil breaks and lets the oil & water mix.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Head gasket failure on a diesel is rare, and is unlikely if it's not overheating. It's likely to be a coolant leak somewhere like the radiator or the pipework.
    Jan 2012
    Vehicle : Vectra c
    Engine : Z18XER
    Mileage : 89000
    well i looked under the cap and couldnt find any "cream cheese" should i take it to a vaux garage to get a tech 2 on it to see if it would come up with the reason?
    Full Member Big Sig's Avatar
    You haven't changed the anti freeze recently and used the blue stuff and not the red stuff did you? If they mix they can foam up.
    Jan 2012
    Vehicle : Vectra c
    Engine : Z18XER
    Mileage : 89000
    no still have the red stuff in there
    Jan 2012
    Vehicle : Vectra c
    Engine : Z18XER
    Mileage : 89000
    ok took it to a dealer and had a tech 2 taken to it. apparently the only things that came up (that i can remember)
    air mass
    something to do with swirl control
    as far as they can tell its nothing to do with faulty gasket
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. White foam in coolant tank
    By Celes in forum Engine & Drivetrain
    Last Post: 14th March 2010, 13:22
