Results 1 to 10 of 23
Thread: ran out of fuel!! :/
    Regular Member ladyvec's Avatar
    Nov 2010
    Merseyside
    Default ran out of fuel!! :/
    Hey guys, not been on here for AGES. I've got a problem, a stupid one like but I'm stuck. I've ran out of fuel its just conked out on me, I tried strtin it again but its havin none. Its a vec c 03 plate dti. Does it need bleeding or can I just stick fuel back in it? Arghh I'm worried.
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    It need bleeding just fill the fuel filter housing up with diesel and the tank then crank it over should fire up ok If it runs then cuts out turn the key on and of a few times then start again
    Nov 2010
    Merseyside
    Whaaaa :'( I don't know what fuel filter housing is. I'm a typical woman with no sense about cars
    Dec 2011
    Lincoln
    Trim : elite
    Engine : 3.0d
    Year : 53
    Mileage : moon&back
    Don't bother bleeding just keep turning it over .
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    Only if u fill the filter housing otherwise don't bother u will flattern the battery
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    I'm pretty sure there's a bleeding procedure for the DTI as the pump can suffer wear if it's being cranked over with no fuel passing through it.
    I'm sure there was a How2 for it
    Oct 2011
    Essex
    And you might need 2 cans of fuel to get enough pressure. What does the handbook say?
    Nov 2010
    Merseyside
    I've tried to put fuel in, its having none of it
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    I Told u that lol u need to fill the fuel filter housing up
    Jul 2011
    UK
    Year : 06
    Isn't there a push button on fuel line to bleed the fuel in
    Was on ny dads old 04 dti elegance
  1. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  2. Fuel housing sensor/fuel temp senser a
    By sri adi in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2010, 10:15
  3. high pressur fuel pump and fuel regulator ?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 12:23
  4. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
