Thread: Spacesaver or steel wheel
    Regular Member coldo's Avatar
    Scotland
    Default Spacesaver or steel wheel
    Hi all,
    I discovered at the weekend that the reason my wheel keeps loosing presure is becuase I have managed to dent the inside of the rimby hitting a pothole... :@
    Anyway,
    I am running 18" alloys at present. The car orignialy had 16" steels on it. I have never even looked at my spare wheel before...
    Do I have a space saver and if so will it be ok to use with the alloys or would I be better putting a 16" steel back on instead?
    Im not planning on using the car much, while the wheel is off being fixed, if at all.
    What's your thoughts...?
    Oh, and here is the wheel...!
    South east
    You'll have a space saver (unless someone swapped it for a steel wheel sometime in the past), but how come you couldn't just lift up the boot floor and have a look?
    (Can someone tell me how much loose change is in my jacket pocket please?)
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    you will prob have a space saver and yes it will be fine to use on your car as long as you go no faster than 50 mph
    Midlands Mod Shop - NFFC.
    Dec 2011
    Seaham
    Think legally, you should only use the space saver spare wheel, otherwise the Police may pull you for having different size wheels on the same axle.
    Scotland
    Quote Originally Posted by Rebellion View Post
    Just asking as the space saver is in the car and Im in work suddenly wondering about this...
    I will be changing the tyre tonight (in the dark) so wanted to know which was the best way to deal with this ahead of doing the job....
    oh and I think you will find you have £3.46 in change in your left pocket...
    Cool... space saver it is tonight!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    You are likely to have a spacesaver in the boot which I think are dangerous. You are limited to 50 mph max and also distance as well (cannot remember how far).
    I owould use the steel wheel and burn the spacesaver
    http://www.autoexpress.co.uk/news/au...vers_safe.html
  1. steel wheel refurbishment
    By DaveG in forum Suspension, Wheels & Brakes
    Last Post: 6th April 2010, 12:41
  2. Should the Spacesaver wheel be 2" smaller
    By 67688c in forum Insignia car chat
    Last Post: 21st June 2009, 21:13
  3. Steel wheel
    By luckyluke in forum Suspension, Wheels & Brakes
    Last Post: 4th September 2008, 13:01
