Results 1 to 10 of 22
Thread: FOR REF: Bilstein B4 shock absorber part numbers for Facelift Vectra/Signum/Estate
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default FOR REF: Bilstein B4 shock absorber part numbers for Facelift Vectra/Signum/Estate
    FOR REFERENCE ONLY:
    Facelift Vectra C/Hatchback/Saloon/Signum/Estate non IDS models
    Part numbers for Bilstein B4 shock Absorbers:
    FRONTS
    22-168597 VNE-G859
    22-168603 VNE-G860
    These are for Facelift cars only and are the same across all trim levels (SRi,GSI,SXi etc) with the exception of the VXR
    REARS
    19-118758 BNE-B875 (same part code both sides)
    Rears fit Preface lift and facelift cars non IDS
    Currently (16th January 2012) for a set of 4 they will cost £227 including postage from LMF
    http://www.lmfvauxhall.co.uk/
    It appears that the fronts have to come from Germany and are not a stocked line in the UK
    PLEASE NOTE: There is a different part number for the fronts for the pre-facelift and these are normally held in stock in the UK and are a bit cheaper
    THIS THREAD HAS BEEN POSTED SO THAT ANYONE SEARCHING FOR B4 INFORMATION ON VECTRA-C WILL FIND THIS POST
    Vectra C
    Signum
    Estate
    Hatchback
    Saloon
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I have today replaced the standard Sachs shocks on our Signum 1.9 CDTi Exclusive with the B4's and they are far better. Combined with the Eibach lowering springswhich were already fitted the ride has vastly improved, it does not wallow anymore. when each corner is bouncd it is far harder. unlike the Sachs ones which were only 6 months old which wallowed away.
    Also fiited uprated Saab drop links from PFS-Wellingborough (£15 each)
    Oct 2011
    Essex
    Cheers for the info - I'm posting in this thread so I can find it again...
    Does it stop the bottoming out? I'm keen to keep the standard springs because I need the clearance.
    York
    Sooty to potentially sound daft but what does the - 'non IDS' mean ?
    York
    Sorry to potentially sound daft but what does the - 'non IDS' mean ?
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    IDS+ (Interactive Driving System) this uses adaptive damping to alter the angle of the chassis when cornering at high speeds, reducing understeer by keeping the body stable and cutting braking distances by stabilising the weight transfer, it works well, giving the car a much tauter and responsive feel than before.
    There's also a button - known as the Sportswitch - which alters the driving dynamics to provide a firmer ride if you wish to press on.
    Aug 2007
    North West
    Trim : SRI With a few added extras
    Engine : 1.9 CDTI 120
    Year : 06
    Cheers for the info merikiito that's going to be useful to me in the very near future
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by andrew e View Post
    I don't think any vectra i have had has bottomed out unless your springs are broken.
    Why do you need the clearance and do you mean ground clearance?
    Oct 2011
    Essex
    Yep, ground clearance - has the lowered springs affected this much?
    As for bottoming out, when making rapid progress on B roads, I get not so much the bottoming out, but I can feel the rear end is going the full extent of its shock travel - did your lowering springs (on your old sachs set up which I have) stem this "wallow" if you know what I mean?
    Effectively to counter act the lift/lightness of the tail end, whilst the nose tries to plow on as the understeer gets ever greater?
    Regular Member mann3210's Avatar
    scotland, perth
    Good thread mate thanks
  1. VXR IDS front shock part numbers..
    By MCD in forum Vectra C / Signum Car Chat
    Last Post: 7th June 2012, 21:29
  2. Shock Absorber part number
    By Bigbaw in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2012, 22:01
  3. Shock absorber part nos.
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2011, 09:49
signum cdti 150 bilstein
vectra estate bilstein b4
vectra c bilstein b4
vectra c estate sri rear shock absorber part number
sinum ftont shocks part number
vectra c rear shock absorbers ids#
vectra cdti 150 rear bilstein
zafira 1.9 cdti sri forum shock absorber
