Thread: Scroll wheels question
    Regular Member johnny kebab's Avatar
    May 2007
    Leighton Buzzard
    Default Scroll wheels question
    Hi All,
    The rubber on my volume scroll wheel has worn away to the point where it's down to hard plastic, anyone got any idea how much a replacement would be from vauxhall or where else to get one from?
    Thanks in advance.
    Johnny Kebab
    Regular Member smiler1982's Avatar
    Nov 2011
    Northampton
    I was wondering this, is it possible to dismantle the unit and rotate the wheel 180 degrees in the housing?
    Sent from my HTC Desire S using Tapatalk
    Oct 2007
    Shropshire
    No the wheel is only a half wheel so you cannot rotate it. I got a right hand one off ebay (they are rarely used compared to the volume one) and took them apart to swap the wheel into my righthand one...
    Regular Member G4GAV's Avatar
    Bristol
    you do get these on ebay very cheap if you look, i got my set and plastis's for 12 quids
    Bristol
    May 2007
    Leighton Buzzard
    Thanks Gav, but they're the wrong colour. anyone else?
    JK
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    but you can swap your coloured bits over
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    You can strip and just change the actual scroll wheels..
    I have done mine and chrisvectra's now..
    You can swap the left wheel with the right (and vice versa) as the left one tends to get used the least..
    Fiddley but not a problem
    Middlesex
    Trim : SRI
    Mileage : 100k
    ....also a note if you are buying a complete replacement control.
    the PREface FULL canbus controlls are different to the facelift controls and are not a standard plug and play fit.
    the PREface controls have a wire hardwired into the conrol that has a plug that then plugs into the steering wheel. The facelift are the opposite where the control just has a socket and the wire and plug are attached to the steering wheel loom.
    HTH
    May 2007
    Leighton Buzzard
    cheers AntSSSS, if I bought a switch to swap the wheels. would it matter if it was a Pre facelift or a facelift?
    JK
  1. 2005 2.2 preface with scroll wheels, traction control switchable?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2012, 10:02
  2. heater scroll knob
    By v6signum in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2012, 16:16
  3. UPGRADE FOR SALE: Scroll Wheels for Steering wheel
    By merikiito in forum Parts for sale
    Last Post: 3rd February 2011, 20:33
  4. Charcoal steering wheel scroll wheels
    By chrisvectra in forum Parts for sale
    Last Post: 18th June 2010, 08:04
