Thread: Loosing oil
    Mar 2011
    Hampshire
    Default Loosing oil
    Hi,
    My Vectra is loosing oil, I'm getting a small patch under the car., every couple of weeks I end up topping up as it's on the bottom of the dipstick.
    I had a look at it today, and took off the engine cover and found this
    Attachment 50590
    I took out the sparkplugs and the second one I pulled out came out covered in oil
    Attachment 50591
    Here is a closeup of it
    Attachment 50592
    The hole where the plug goes is oily as shown in the image below
    Attachment 50593
    I had a look underneath and it's covered in oil
    Attachment 50594Attachment 50595
    Also the car seems to be loosing coolant, I've checked the oil cap and there's no mayo.
    Any suggestions where I should look next? As I want to try to stop something major happening as I've already had a failed waterpump that caused skipped timing and that caused most of the valves to be replaced. I was lucky as the pump was only changed in march and the job to fix it was done on parts warranty.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Replace the cam cover gasket. That will sort it
    Mar 2011
    Hampshire
    Thumbs up
    Thanks, replaced the cam cover gasket and now it's not leaking. Also the garage that replaced the waterpump and valves didn't put the cam cover back on properly. A couple of the bolts were sitting proud of the cover and not holding it down, i put them back on correctly.
    Now it doesn't leak any more!
    Thanks for your help.
    Matt
    Nov 2011
    Good stuff!
    Happy to help
  1. Loosing Coolant
    By Coupe2T in forum Engine & Drivetrain
    Last Post: 2nd April 2012, 10:03
  2. Help - loosing power
    By ps2user in forum Vectra C / Signum Car Chat
    Last Post: 9th September 2010, 14:04
  3. v6 loosing oil
    By lilangel in forum Engine & Drivetrain
    Last Post: 2nd May 2009, 20:18
  4. Loosing confidence in my GSi!
    By byebyeitsagsi in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2009, 20:33
  5. loosing a friend
    By lborob17 in forum General Chat
    Last Post: 4th July 2006, 14:41
