Thread: A few simple questions
    Jan 2012
    Wicklow
    Default A few simple questions
    Sorry for this guys but me and the vectra are having a few teething problems and i'm hoping you can help, just it didn't come with a manual so i'm a bit confused. the car is a 03 saloon 2.0DTi
    how do you open the boot? there is a button on the drivers and passengers door but all the do is make a "beep" noise and doesnt open the boot? when the car is unlocked if i press the button on the boot it doesn't open. the only way i can open it is by pressing the boot button on the keyfob and this gives me around around a 15 second window to press the button on the boot to open it but then thats it. surely there is an easier way?
    also when i press the lock button on the keyfob all the doors lock fine. but when i press it to unlock it only unlocks the drivers door and i have to click it twice to open all the doors, is there a way to make this one touch?
    the brake wear warning indicator come on the dash from time to time even though the pads are fine, i believe bridging the wires on the sensor is a means of getting it to stay off?
    and my temp gauge is all over the place, sometimes it doesn't rise on an hour long journey, sometimes its perfect, most times it sits around 75/80oC. am i right in thinking this is likely a thermostat issue?
    and lastly my heaters only work on speed 4 but i read a nice repair guide on here, so cheers for that and any advice i get
    Full Member daddyjay's Avatar
    Jan 2010
    poole
    Vehicle : vectra facelift
    Trim : sri
    Engine : z20net 2oltr turbo
    Year : 57
    Mileage : 38200
    you still have to press the button on the boot as it is not auto open.
    to unlock all the doors you have to press the unlock on the key fob twice think this is a safty thing.
    newport
    all the boot button on the doors do is unlock the boot, you still need to press the button on the boot to open it.
    my car is the same as yours for unlocking, 1 press unlocks drivers door, another press opens the other 3, a complete pain in the arse, but ive found no way to change it, there is a guide for opening the car on 1 press, but my car doesnt do this
    Jan 2012
    Wicklow
    Quote Originally Posted by taffy bhoy View Post
    that solves that perfect, thanks
    i was clicking the buttons on the doors like mad thinking they "popped" the boot open, so i must be out of sync with it now. because no matter what i do the boot wont open.
    i'l have a look for the one touch guide
    Wondering lonely as a cloud
    23 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Quote Originally Posted by OpelVectraC View Post
    how do you open the boot? there is a button on the drivers and passengers door but all the do is make a "beep" noise and doesnt open the boot? when the car is unlocked if i press the button on the boot it doesn't open. the only way i can open it is by pressing the boot button on the keyfob and this gives me around around a 15 second window to press the button on the boot to open it but then thats it. surely there is an easier way? This is normal it is a security feature so that your boot can't be raided at the lights the beep noise means like the key fob button it is available to use for a short time does the number plate light come on with the beep it should do to show you its opened
    Again this is quite normal so that if you unlock the drivers door the world and their brother can't just jump in the other doors
    the brake wear warning indicator come on the dash from time to time even though the pads are fine, i believe bridging the wires on the sensor is a means of getting it to stay off? Its an earth connection through the disc that makes it work so remove it and tape it up out the way or buy another sensor they are less than a tenner
    and my temp gauge is all over the place, sometimes it doesn't rise on an hours journey, sometimes its perfect, most times it sits around 75/80oC. am i right in thinking this is likely a thermostat issue? 95% certain to be the thermostat most folk have worried about this but a new stat will make things right again
    Please read the responses above in RED
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    You get to program thinks like door unlocking on the Insignia.....
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 131000
    try this
    hope this helps
    http://www.vectra-c.com/forum/showthread.php?t=98997
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 131000
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 131000
    http://www.vectra-c.com/forum/showth...t=scuttle+tray
    you have a bit to read now hope this helps
    Nov 2009
    N/A
    Quote Originally Posted by paulhb View Post
    as he said, re the blower on setting four only, there are two normal causes to this, one is the resistor on the blower motor (£30ish from the stealers) the other is the relay in the passenger relay panel (£7ish from the stealers)
  1. 1.8 vvt simple changes for better MPG?
    By Chip in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2012, 16:31
  2. Want a Simple Phone?
    By RobW in forum General Chat
    Last Post: 17th February 2011, 23:07
  3. Simple little sum....
    By danBoy in forum The 'Off Topic' room
    Last Post: 8th February 2009, 18:56
  4. PC or Mac simple as that!
    By Brocks in forum General Chat
    Last Post: 11th January 2008, 21:56
  5. 2 Simple Questions (peeps in the know..)
    By rscosworth in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2006, 22:53
