Thread: 2.2 se water pump/ temp gauge problem.
    Regular Member james chambers's Avatar
    Sunny Leicestershire
    Trim : SRI
    Engine : Y22SE
    Mileage : 100,000
    Default 2.2 se water pump/ temp gauge problem.
    Hi guys, last tuesday I replaced the water pump on my 2.2, after I finished work, luckly i'm a techie at a local villiage garage, all went well changing the pump so that was all good,
    I left it on the ramp whilst I mopped up the mess under my ramp and left the car warmed up, once hot the cooling fan came in and everythings good! Soooo, I locked up and set of home for the night,
    as the car got to running temp I noticed that the gauage creeped up a little more than 90 degree's ( ive owned the car 3 years and it never goes above 90 on the gauge) so I put the heater on "hot" and the fan on full blast and that bought it back down abit.
    I got to work on wendesday and checked the water level and all ok there, but it creeped up again on the way to work then settled again, as I pulled into my parkin space i heard the cooling fan cut in and out and the gauage was around the 95 degree mark,
    That night after work i pulled it back into the workshop and checked for air locks as by this time i'm getting paranoid!!! but everthing checked out ok! grrrrrr!
    (at this point I have to say the bottom hose of the rad only gets luke warm,) (as I cant remember ever noticing before the temp of it?)
    and once again the temp gauage creeps up and drops again when the fan comes in.
    so on friday I spoke to Vauxhall Techinical as were a trade club member and the chap on the other end of the phone said that i'd done everything i'd done was correct and had a head scartching moment with me.
    so i left it and decided to run it as all seems ok apart from the temp gauage creeping up and the dropping once the fan comes in.
    Over the weekend ive done around 300 miles with this happening and most of it has been motorway work, and the gauge was sat just below 90 degrees and just seemed to creep up as i slowed in traffic and traveling though villiages??
    And I seem to have chilled out a little, as i'm really anal about my cars and it always seems worst when you have alot of knowlegde and your so deep into it that you can't see the end of your nose if you understand where i'm coming from???
    So the question is!!!!!
    Where does your temp gauage sit?
    and do they creep as the car gets hot (like a older car) as i'd never notice this before and now it's giving me kittens, also would you be able to check your botom coolant hose and see how hot yours get after a run, I would be really grateful! James Chambers
    Nov 2009
    N/A
    Quote Originally Posted by james chambers View Post
    Once mine has warmed up it usually sits just to the left of vertical (can't remember what value that is, I never concentrate too hard on that gauge!!) If I'm sat at lights on in traffic for a while, it occasionally will creep to just right of vertical, but never by very much
    Dec 2011
    Seaham
    Mine is just to the right of vertical, if you are not losing any water, then I could only suggest a slightly sticky thermostat. Mine stuck earlier, but stuck open, however it appears to have sorted itself now???
    Trim : SRI
    Engine : Y22SE
    Mileage : 100,000
    thank you, keep them coming! untill I changed the waterpump it never seemed to move,
    Having the exact same issue with mine ever since I had to remove and re-fit the bottom hose to the expansion tank!
  1. temp gauge problem or not ?
    By madmark in forum Troubleshooting
    Last Post: 29th January 2013, 22:27
  2. Water temp gauge
    By obews in forum Engine & Drivetrain
    Last Post: 6th August 2012, 19:07
  3. 2.2 se water pump/ temp gauge problem.
    By james chambers in forum Engine & Drivetrain
    Last Post: 19th January 2012, 02:13
  4. water temp gauge
    By vectra.sri in forum Engine & Drivetrain
    Last Post: 26th August 2011, 00:18
  5. Temp gauge problem?????
    By stubopvectra in forum Engine & Drivetrain
    Last Post: 4th March 2008, 21:31
